weird cotton candy sky thing going on lol
Truck looks sharp. The white letter tires really set the wheels off.
Traded up from a white LT to a black High Country. I forgot what a pain black was, but well worth it when it's clean!
  • Like 4
here's mine after removing all chrome and going blacked out. looking to do something with head lights next
I like the wheel swap. Looks good
Looks good... Are those the "gunmetal" wheels or the standard finish? Hard to tell with the lighting.
check out www.lamin-x.com I used this on my truck ( tint color ) low , hi , fog's
Not black enough for me yet, either going to try plastidipping the "silverado" lettering or have it painted. Also eventually the front bumper will get a gloss black wrap. Probably ditch the 4x4 stickers also.
Not black enough for me yet, either going to try plastidipping the "Silverado" lettering or have it painted. Also eventually the front bumper will get a gloss black wrap. Probably ditch the 4x4 stickers also.
blacked out look is sharp. I get a lot of looks and compliments on the blacked out look. I debadged my Sierra
Good looking truck, you from Sarasota?
Thanks! I live in Bradenton, but use the SRQ for the area.
Srqsierra, use to have a Ridgeline and used srqridge on the Ridgeline Forum
Definitely a nice upgrade. I went from a Frontier to my Silverado, and never going back!
I'm from Venice/SRQ originally, but live in GA for another 6 mo. Then it's back to the 941 !
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,284 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
