Might as well post one in this thread, too.
What are the details? Tires, wheels, backspacing, level. Love the look.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Never mind, I found the thread you started
Thanks. Wheels are 20x10 Hostile Sprocket with a -19 offset. Tires are Toyo Open Country RT 33X12.50R20.
pic of my new 2016 Denali
Edited by Holty
Those wheels are haunting me. I opted for the CK162 Black 22" wheels on my black Denali but every time I see these I get a little buyer's remorse (although I do like my wheels). I think I have A.D.D... my truck's not even a month old yet.
Looks very nice.
What lift/leveling kit do you have installed here?
This looks awesome man! Did you put a new front grille on?
Thanks! I searched regularly on Craigslist and EBay for Midnight edition front end parts. I finally scored the grille and headlights after months of searching. Grille is Midnight edition, but the headlights are dealer-painted.
Best looking GMC out there by far. That was the color combo I had on my radar. Maybe next time
i had seen a picture on instagram of your truck on a gm page. looking sick small world!
Any good threads on here for cleaning regimens for black trucks? I searched around a little but couldn't find much.
the rainx spot free car wash actually does work well at keeping water spots away. wash it in the shade or at dusk and get a silicone water blade to finish drying it. sucks this time of year tho u wash it and the next day its yellow again
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
