Auto A/C and Vents Used
I'm not sure if this is normal or not and looking through the owners manual doesn't specify.
When I use auto temp control and its hot outside I get cold air coming out of all of my vents (or at least the front vents).
When its cold outside it blows hot air but never out of the front vents, almost like its on defrost. Is this normal? I can manually change it to blow the hot air from the front vents and disengage the auto temp, but it really confuses me why the auto won't do it. My last car with auto temp control worked the same whether it was blowing hot or cold air.
I believe what you described is normal. It's trying to predict where you would direct the air to if you were doing it manually. Full auto will turn on the rear window defroster as well, if it thinks it should.
Auto temp should control the temp even if you have overridden where the air is being directed to.
Hi c0ld29,
I understand that you have a concern with the vents in your Silverado. I am not able to provide technical advice, but I can certainly look further into this matter for you. Please send us a private message with your VIN if further assistance is needed with this matter. I look forward to hearing from you soon!
Kristen A.
GM Customer Care
Warm air comes out the floor, outer (but not center) dash vents, and sometimes the windshield. This is pretty typical for every vehicle I've owned the last 10 years.
Thanks for the replies. I live in southern Louisiana so the heater isn't used nearly as much as the a/c, but I just wanted to make sure it was normal. My last car with auto a/c was a 350z so maybe Nissan does it different or I was just remembering incorrectly.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
