Window Vent Visors
I haven't added Vent Visors to my 2014, as I am very uncertain of what brand to go with.
I really like the look of the type that mount inside the window track. Very "Clean" look, and not bulky. But I've heard of some folks having trouble with this type staying put in the channel.
If you have the "In Channel" type, please post your thoughts. I would like to go this way but still not convinced this type works all that well.
REV
I have the weathertech in channel ones. They clip in the window channel with clips not tape. So far really like them.
I also have Weathertechs and love them. They're also low profile. The front just slide in there, you just have to bend it to get it in there which is what's in the directions. The rears have 2 clips on each side that slide in the channel and hold the visor. I've had all of my windows down going 75 mph for a good while and no rattle or anything. I also like that they don't use tape at all. I had AVS stick on type on my old truck and one came undone and wouldn't stay so I'll always get in-channels from now on. Just make sure you do what the directions say. These once you install them you roll the window up and down 5 times and then keep the windows up for a full 12 hours straight to help them stay.
I have the WeatherTech's just on the front windows (no clips needed on fronts).. so far, not complaints.. can't wait til spring to try them with windows open!
I used EGR in-channel on my last 3 trucks ... No problems ... Great fit ... cost is a little less than WeatherTechs ... I believe their factory is in Cali.
You like the EGR? I'm thinking of a set. I had the WT and the rear ones are pure garbage imo. They fell off even with the clips and scratched my window. Now I'm gun shy on these deflectors.
I'm sure you didn't install the WT right. If the rear is installed correctly there's no way they would fall down. . I had mine installed wrong for about 3 months. But im sure the other are just as good
No offense but look around lots of other people with similar problems on the rear WT. I'm positive mine were installed correctly. Those clips only really go in one way. I left the windows up for several days and added 2 sided 3m tape. Mine did not come with any tape. Every time I would roll the window down, down they came about 1/2"-1 or so. I will say the fronts fit and looked nice.
Like i said i installed my wrong as well. Sounds like what you are saying you installed like i did the first time.. the wrong way. You've to like pinch the rear clips to get them in the rgt way.. the instructions from wt sucks.
I have Putco in channels. No problems with the backs coming off. Not sure if they use clips or not. I like how they are more square and have lines that match the truck.
The rear set of my Weathertechs actually fit more snug than my front once. The clips don't scratch the window either. When I put the window down they don't move at all, not even a little. The front ones did move in just a tad at first but they seemed to have stopped just before it started to get cold.
I got them last year when first released so maybe they have improved. The clips didn't actually scratch the glass. The rears slid down while on the highway last winter and some road salt got stuck in there.
I did as the directions said and after installing I left all of the windows up for 12 hours (after moving the window up and down 5 times). The next day after installing I went down the interstate and none of them moved while going 75 with all of the windows down. I bought mine in August. The clips for the rear did seem to be not really a pain, just had to make sure they were all the way in the channel.
I had looked into EGR in-channels since that's the brand hoodshield I have but I saw a review from someone with a '14 where it messed up the automatic windows in some way. I think they didn't allow the windows to go all the way up and wouldn't stay up or something. So just to be on the safe side I just got the Weathertechs and so far no complaints after about 5 months.
Whoever said that the EGRs messed up the auto window feature did not know what they were doing when they installed them. They fit perfect and were simple to install on my 1500 DC.
    C. Hart
    C. Hart
  • Who's Online   3 Members, 0 Anonymous, 551 Guests (See full list)
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
