Phillips 9011 bulbs
Sharpb
I have a set of 9011 bulbs on the way. I know from reading other posts that I will have to modify the plug housing. My question is: Has any one who put these bulbs in had any problems, i.e. re-aiming headlights or wiring issues?
  • Replies 52
Not I. I haven't seen or heard of any problems either. I posted the "how-to'' pix using a wood chisel to cut the ribs out of the socket and clip the lock tab. Don't modify your plug on the truck. Just do this to the bulbs.
the bulbs pull higher watts. since the voltage (electrical "pressure") in the vehicle should not change, that means they see more amps (electrical flow). more amps means more energy at the filament-- meaning more lumens.
i'm sure an electrical engineer can poke holes in my explanation here :)
I put the 9011 on my Silverado. All they needed was the one tab trimmed. No ribs were present in the bulb socket like pictured above. Super quick and yes they are brighter and a tiny bit whiter.
How hard is it to get to the headlights under the hood?
If you don't have a spare battery, the left side is directly accessible without any tools. The passenger side requires that you loosen the hose clamp at the air cleaner box snorkel, push the hose back, unplug the MAF sensor, and yank upward on the air box by the snorkel until the three grommets on the bottom of the air box let loose. Remove the air box from the engine compartment. The rear of the headlights will be directly accessible thru the plastic cap at the rear of the assembly. Access takes less than a minute after you've done it a few times.
What brand were the bulbs? The bulbs in the pictures above were the Philips from Home Depot online. The 9012 does not have the ribs.
Topic said Phillips which I assume is the bulb brand.
I've been looking into this myself. Is there a perceptible difference in light output?
Yeah, I had to wait a couple weeks for Home Depot to get some in stock
You've got it right...except for one addendum....higher wattage=more heat at the bulb, the connector, AND the wiring, as well as possibly blowing a fuse. Instead of changing to a higher wattage bulb, a better approach would be changing to a more efficient bulb pulling the same or less current, but with greater light output. LEDs come to mind here, as well as a few other choices.
In theory, what you said is true about an LED being a better choice. . However, while some LED bulbs may generate more light output, there have none that seem to have more useable light output when mounted in the Sierra projector due to the specific arrangement in the reflector. Still waiting for that.
The wiring in the truck is protected by the fuse. The fuse and wire has plenty of margin to handle another 10 watts. Touch the wires if you like. I ran 65 watt bulbs in my 2008 truck for 5 years with many all night drives. Never had a problem. Others had the same. No electrical engineer cuts it that close when sizing a light circuit.
You
Being an EE myself, you'd think I'd agree with you on this, but we don't always have the luxury of a nice, wide design margin. Bigger safety margin costs money. Even a few cents' worth of wire can be shot down my the budgeting bozos. I wish that weren't the case, but that's the way it is.
Oh....and you might want to re-edit your post and kill the repetition.
edited to add:A 20% increase is cutting it a little fine. Typical design safety margin is ~ +/-10 % at MINIMUM.
    btm
    btm
  • Who's Online   4 Members, 0 Anonymous, 1,354 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
