Phillips 9011 bulbs
Sharpb
You
Being an EE myself, you'd think I'd agree with you on this, but we don't always have the luxury of a nice, wide design margin. Bigger safety margin costs money. Even a few cents' worth of wire can be shot down my the budgeting bozos. I wish that weren't the case, but that's the way it is.
Oh....and you might want to re-edit your post and kill the repetition.
So you're saying there's risk. Like any change, there is risk. The issue is: what is the risk? Is there a risk of blowing a fuse? What's the probability? Is there a risk of frying the wires? What's the probability? Since no one has proposed changing the fuse to a higher amperage rating, the wiring retains the OEM circuit protection, I think we can agree. So, this is an academic discussion about the possibility a 25 cent fuse may have some unknown added risk of blowing.
  • Replies 52
I've had the Phillips 9011 in my truck for a year now, no issues and never blown a fuse. Wiring is fine, light output is better. It is brighter and a little whiter as said. NO extra heat either, front of the headlight feels the same as stock.
Dumb question: where are you guys using the 9011s? I've read all the bulb threads and my head is spinning with all the numbers.
They are being modified to fit into the Sierra projector.
Thanks! I think I'm stuck with LED or HID to upgrade my non projector Silvy low beam H11 then.
You can shoehorn a H9 into the H11 socket by grinding a tab down a bit. I used them in my 08 silverado.
Silverado highs for me.
Do they only have a standard Phillips 9011 bulb or do they have other models like crystal vision
The few different places I looked, it was a standard Phillips 9011 bulb. I ended buying mine through Home Depot, I think they were around 17 bucks apiece
I haven't seen any other variation of the 9012 and 9011 other than standard clear. The 9011 and 9012 are a HIR specification (halogen infrared reflective) which was originally using an enhanced technology with the halogen lamps. These new Philip bulbs have mixed reviews on their performance compared to the original 9011 Toshiba HIR bulbs that were the supposedly first on the market. I've seen some reviews stating that these Philips were not as bright and some that said they were brighter.
The main thing is that they meet the spec and the 65w 9011 is about 25% brighter than the 55w 9012 (Sierra OEM low beam).
You Silverado guys really need to look at replacing your low beam H11 bulbs with the 65w H9. You can buy a jumper pigtail from Bulbzilla (on amazon too) and grind a tab back a little and it fits. It's a decent boost in light for the lows. I ran them in my 08 Silverado for 5 years and they're still in there. They do have a short life. I was replacing them about once a year. But they are available at all the O'reilley and Autozone stores for $14 each.
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
