2009 Silverado HD Electrical
A good while back I posted a topic on this forum asking about the proper way to run cable to power a winch on a trailer. I bought 25 ft of 4 gauge cable, two quick connects, and a battery cutoff switch. Today was the first time I've actually used it, and everything works great. I want to thank everyone who contributed to that post.
Now for the problem. I let the truck idle when I'm using the winch. The lights dim, but not enough to make me worry. I'm getting "check battery charging system" on the DIC. Am I overworking my electrical system, or is my alternator weak? I've gotten this message before with just the extra load of the trailer lights on the system.
I'd say it's the battery, not the alternator. You're probably still running the original battery right?
Yes I'm running an original style battery. When I replaced it a year ago, I put a little heavier one in it. I forget exactly what it is rated for, or what the manufacturer originally called for.
Would an Delco battery go bad that quickly?
