  • 7 months later...
Have 2015 GMC Sierra chrome trim, wanting black will trade.
Also will trade chrome door handles for black
And even mirror caps.
Located in Brunswick ga.
Ive got chrome to swap for black as well. 2015 sierra crew cab. Send me a msg if interested. Located in Dfw Tx area.
Edited by Glasshouse
I've got chrome looking for black. 2016 Crew Cab Located in New Hampshire.
Are the black just plastic? Anyone got an up close pic?
2014 crew cab looking for Chrome. How difficult is it to swap these out?
  • 4 years later...
Anyone still using this thread? Interested in swapping chrome trim from a 2017 Sierra crew cab for black.
