I have a 2007 gmc 2500 hd with what i suspect to be a tcm issue. Must things i have read show the location on the radiator shroud but it is not there. any suggestions where it could be?
If it is a 2007 "new" body style (2007-2014 body) HD with a 6.0 and the 6L90, the TCM is internal to the transmission. If it is a "classic" body style 6.0 4L80E truck (1999-2007 body) its under the battery tray, driver's side of the truck.
2007 classic with Duramax its left side, upper fan shroud. If its 2007 new body Duramax, its in the same spot.
Edited by newdude
It is the newer body style. It's a gas engine with an Allison transmission. Not sure if that changes location.
Gas engine does not have the Allison its a Hydramatic 6L90. Its in the transmission. If you drop the pan its attached to the valve body.
Not sure that the TCM is even the issue. It doesn't crank. There is no line under the shift selector and I cannot get any communication with my scan tool. If I cycle the key enough I can get the line and it will start for a few seconds the die. Read a ton and was hoping for a bad ground in the TCM
Definitely has an Allison I believe it's an 8.1 gas engine
So its not a "new" body 2007-2013 its a 1999-2007 body with an 8.1 and Allison...drivers side of the fan shroud almost under the upper radiator hose.
If its not there...I have no clue lol.
If you have no line under the PRDNL the internal mode switch/range position switch on the drivers side of the transmission could be shot and it can't detect gear position and won't let it start. Older Allisons had a different switch set up (Neutral Safety Back Up switch) that would fail (corrosion, swell and crack) and would cause all sorts of issues.
If that is bad, the valve body has to be dropped to change the switch.
The 8.1 and Allison trans was not available in the 2007 HD, only the Diesel's came with the Allison. The 8.1 with the Allison ran from 2001 to 2006.
Edited by Silverado4x4
Not sure on motor but was told its a gas with Allison its a 2007 and I do believe it's the new style. What would be the tell tale sign of an Allison vs standard trans?
Edited by poreda
Omg dude just take to a shop !!!!!! You don't have a clue what you're doing , except wasting money , STOP IT NOW !!!!
You have no clue what I know. Obviously this is not a place to get help!
No it is a place to get help but when we have to pry the info out of posters its a problem. Do you have a VIN number? That would be worth gold for one of us to help.
It's a friends truck so I apologize for not having all the info. I will get the vin and post it. It's be to the dealership 5 times with no solution. I have seen these forums do wonders to help when the dealership cant. The original problem started with the truck going into limp mode and has progressed into a no crank situation.
Its all good sir. If you have the ability to private message the VIN if you don't want to post it thats fine. Not sure if there is a post limit before you can.
2001-2007 had 6.0, 8.1 and Duramax. 2007 Classic was the last year for the 8.1 option.
2007 Classic Body:
2007_gmc_sierra-2500hd-classic_crew-cab-
2007 new body style would be 6.0 and Duramax only.
2007 New Body:
2007_gmc_sierra-2500hd_extended-cab-pick
Edited by newdude
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
