8 Speed TSB update
Ron.s
Thinking about getting rid of my 2014 and getting the 6.2 with 8 speed. Has anyone had the recent update to the transmission program? Did it resolve the clunky shifting?
Read the topic
Anyone with a 2015 6.2l with the 8 speed auto?
I would wait if I was you
Read the topic
As some on their 2nd clunky transmission in less than 1800 miles, I second this advice. It'll be nice and smooth then first 100 miles and then slowly start going downhill from there. On this second one, I can hear almost every shift as a click if the music isn't up.
GM knows they've got a problem, but hasn't found the root cause yet.
I've got more than 3200 miles and the transmission shifts smoothly, but I do get the occasional clunk when taking off from a stop, and even more rarely on quick deceleration. If the radio is on its hard to hear. Sounds like loosness in the initial shift. We're it not for the occasional clunk it would be perfect. Just have not had time to take it in and when I talked with service manager he really wasn't aware of that problem with the new 8 speed, so it's like " what's the point of taking it in if they're not familiar with the issue.
Same situation here too for that first shift - occasional clunk when starting from stop and an occasional clunk when letting off the pedal if I'm going around 20-30 mph. Other than that, no issues and smooth shifting. Mine has 3100 miles on it.
I'm in a new 15 with the 6 speed as a loaner and it dose not make the first sound so that means to me thAt something is not right with the new 8speed that cost more to get because it was "better"
Try cruising at 35mph in M5, then shift to M6. Then back to M5 a 5-10 seconds later. I wouldn't be surprised if those shifts are very audible clicks. The more miles I got on mine, the louder that shift got.
Same thing happened to me.......started with the initial acceleration/deceleration clunk....then moved to a clunk between 5-6.....now its almost every gear, however after the PI1388 (dont quote me on that exact TSB #) the initial clunk on acceleration has occured less and less, but the transmission now appears to be more and more lost in trying to find and hold the right gear.
Im in a 15 Tahoe with a 6-speed as a loaner right now and it runs SO much better that the 8-speed.
http://www.gm-trucks.com/forums/topic/164949-anyone-with-a-2015-62l-with-the-8-speed-auto/?p=1572545
You are correct. PI1388. I will have them look at this at the same time they are doing PIT5374 for the headlights.
I wonder how good will be the 26 speed they are planning for the 2021 model. It will shift so often you will not even notice it, even if it jerks :rolleyes:
That's going to be the new model coming out right is called the clunk o junk I heard
All jokes aside, I think a good after market tune is your only option to get these to work properly. GM has got so wrapped up in maximum fuel economy numbers that they tuned these transmissions to go into the top gear as soon as possible, causing less than optimal shifting and sensation of the same.
ahh , how can i forget ...the ole tune my brand new truck so its runs " Normal"
Sorry guys...as i said before aint no way on gods green earth I would tune this BONE STOCK truck.
    KirbyCo
    KirbyCo
  • Who's Online   5 Members, 0 Anonymous, 1,427 Guests (See full list)
