Bad tow strap story
RyanbabZ71
I dont know if the article is still on the local website but ill paraphrase it
Two guys were out offroading by wolf lake (indiana tollroad close to illinois).  One guy got stuck so the other guy hooked a tow strap up to pull him out.  He used one with the hook on the end.  Well it didnt go so good and as he was pulling him out the towhook broke loose and went through the guys windshield lodging it into his head.  Rescue crews couldnt get to the guy cause it was so muddy until they found a 4wd truck.  Two days later the gentleman past away from his injuries.
Just wanted to say becareful when using a tow strap especially the kind with the hooks on the end (use the kinds with the straps)
:chevy: I seen a picture once where someone was using a smaller truck to pull out a bigger one and it didn't work to well and ended up pulling the ball out of the chrome bumper and slinging it through the other trucks windsheild. :cool:
Yea you can never be to careful.  Here are a few tips for ya.
When using a winch or a tow strap you should always:
1. Put the hook with the open end facing up (Hook in from bottom) so that if it slips off it will more than likely go down into the ground.
2. Place some towls/jackets/blankets or whatever you have with you over the middle of the strap or cable.  That way if it does fly through the air it will have more resistance. and slow down much faster
3.  Make sure that what you are attatching to can handle the stress.  Examples would be Tow hooks bolted to Chassis or heavy duty off road bumpers. A tow hitch would work as well. What not to use would be a welded tow hook / factory bumper / body pannels and suspension or dive train components.
4.  Always hook up below the bumper line.  Anything higher will cause more stress and will throw off the balance.
These are just things that I came up with off the top of my head that I remember reading at variouse web sites.  I also did a lot of raock crawling and mud bogging with my ATV and have had to use straps and my winch quite a bit.  If you have to use any of these please take care when doing this because I know people who have had close calls.  Thank god no injuries.
Later,
Brandon
I agree but sometimes you have to hook it to what you can.  Happened to me last may.  My dad got stuck at our summer cottage.  There is a nice slope down where we park.  It rained all weekend (my truck sunk into the ground about 3-4 inches) and his tires were bald.  Only thing i could hook a strap up to was his bumper (92 S-10).  I for sure thought the bumper would be ripped off but amazingly it was attached better than i though
I agree to.  If yu only have a few things to work with that is what you have to do.  I had a Dodge Neon and I slid off the road on Ice and was stuck in a snow bank.  Car was compleatly High Centered.  My dad pulled me out using the Front bumper and hood mount beam.  Got it out but the hood didn't like to close any more.  Not until I took a hammer to it.
Ouch  :chevy:
Wish we could use tow straps but those would just snap after the first tug . we use nothing less than 3/4 inch cable weighted down in the middle of the line to get our stuff out of sticky situations  :cool:
I once read a story where they were using the stretchy Tow Strap where you pull until ful stretch then let the strap pull you out and then pull again.  Well it was a Suzuki Samuri that was stuck in soup up to the floor boards.  A Dodge ram 2500 was pulling him out.  Well the strap came to full stretch and it was slowly pulling the Suzuki out when everyone heard a Shotgun go off.  It was no shot gun but the Suzuki's welded on tow hitch.  And the driver of the Ram was screaming.  The weld broke and the strap shot through the Tailgate.  Through the end of the bed, Through the cab, through the seat and stuck in the dash.  Thank God it was on the passenger side.  I saw pics of it and it was some really crazy shiznat.  I was pretty warry about towing and pulling after that.  That was when I took to time to educate my self.
Later,
Brandon
I have a pic somewhere of a Jeep w/ 44" tires sitting on dry ground.  There is a tow strap hooked to the front bumper on one end.  If you follow the strap looking for the other end, it goes over the hood, through the windshield, and through the head area of the high-back drivers bucket seat.
Similar situation, years ago, we were pulling my cousin on a tractor inner tube at Santee (large lake system in SC) with an outboard powered boat.  He was bouncing around pretty good.  One time he hit a wave and the entire tube went under water.  He popped back out to catch the cleat/tow rope mount in the middle of his forehead.
Fortunately, all he got was a pretty bad scar.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 721 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
