Tie Rod Upgrade
14x4
I apologize if there is already a thread on the subject. Couldn't find any info.
Anyone know of an aftermarket/heavy duty tie rod upgrade for 2014+ 1500's? I couldn't find any manufacturers that make them for the K2XX's. I didn't even find much for the 07-13 trucks.
Are our tie rods interchangeable with the 07-13 trucks? What are your opinions on the necessity of heavy duty tie rods for running 35's? I'm not aware of any lift kit manufacturers including heavier tie rods with their lift kits, so everyone running lifts and 35's are still using factory rods without any reported issues, correct?
Thanks for the input.
EDIT: Readylift has upgraded tie rods for the 07-13 trucks, but they're heims. Looking for sealed joint.
Readylift Heavy Duty Steering Kit
To be honest Ive browsed through the Internet and it's rare to me when I see a lift kit with new tie rods today's trucks usually utilize the stock but I'm pretty sure some one can chime in and give u better directions the best I can do.
