18" Gloss Black Wheel Skins
I'm not so sure how gloss black wheels would look on on my truck. I'm not willing to make a $2000 investment in wheels and tires for something I may not like. I was thinking of spending $90 on a set of 4 wheel skins to see how they look. Has anyone tried these? They may look cheesy or not, just don't know - anyone have an experience with these wheel skins????
http://www.ebay.com/itm/221696137312?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Yes, yes yes.... did that already but was wondering if anyone has seen the wheel skins in person. Not sure if they are passable or cheesy
They look like they could be passable, until someone touches them or ask you and you have to tell them that they're basically hubcaps on the next level. I personally would rather have them the stock color than have "level 2" hubcaps over them.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
