Everyday carry is a Glock G43, G22 in my door pocket and for my hunting carry G20sf
Pack a Left Hand Randall stainless LaMay 45 ACP. Truck gun is a Beretta 9mm 92F, with flipped mag release as I'm a portsider.
In a few months i may pick up a P239 in 9mm. Depends on how i like my P229 on a daily basis
Springfield XDS 9MM. If I'm OC, it's one of my many 1911's lol
1911's, over 100 years old and still going strong. Being that you are Texan, same as me, you've probably noticed that a lot of Texas Rangers pack the 1911, and carry cocked and locked. The only way :)
Yes sir. Many of the sheriff's and constable around here so the same. As well as myself. Only way to carry....condition one!
Texas chl is now ltc license to carry.... When I complete my certification I will be carrying my vz 82..
  • 3 months later...
Glock 43 as a daily with an extra mag since it's a single stack. Every once in a while I'll pull out the M&P 9 or FN-X 45 if I'm carrying open in the woods or with a heavy hoodie or coat during the winter.
Installed a APEX trigger on my M&P. Fantastic investment over the garbage trigger that comes stock.
I don't have a carry permit, but I plan on getting one as soon as I can which probably won't be soon either.
Right now I have a Glock 19 that I plan on carrying. I also have an M&P 40 full size, but that will stay at the house. When I do get a carry permit I also plan on getting a Glock 26 as a backup and will get it either before or around the same time as getting a carry permit. I say 26 so I can use the 19 mags for both guns.
I have a Apex trigger and sear in my M&P 40 and it feels a lot better. I only got the trigger because I guess I didn't really like how the trigger is hinged in the middle so I prefer the piece in the center like the Glock and Apex trigger is. I got the polymer one because I didn't have a reason to pay double for the aluminum one.
I also installed a Ghost trigger connector on my Glock 19 and that helped it make the pull a little lighter and made it smoother.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,066 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
