2000 chevy 2500 4x4 wont engage
Hi I have an extended cab long bed 6.0 2500 (non hd) I dont know if that makes a difference or not but a couple months ago I slid off into the ditch and hit my front end and slightly bent the frame well my buddy is straightining it for free so when I went to put the truck kn the trailer cause the radiator it cracks I put it in 4x4 to climb on the trailer and all it did was sat there and blinked I couldn't tell if the actuator was wprking either I figure I ****ed up something so im looking along the lines of a sas unless someone can enlighten me on how to fix this
I didnt know that 4x4 would show up on codes ill do that first thing tomorrow and reply with what I see
If you do have to buy a code scanner, you might consider buying a higher-end one, like an Autel MD802 [i happen to have picked one up on sale for about $300 CDN]. It not only show basic ODB II codes, but it also displays [and stores so you can download them on your computer] live data for your engine and transmission [and probably also your transfer case], air bag codes and ABS codes. And it supports a bunch of NA, european and asian cars, and Autel puts out updates for it for news vehicles. I found it really useful for figuring out what was going wrong with my '04 Sierra 3500 w 6.0L gas motor.
The only thing that is stupid about the setup is that Autel STILL hasn't updated their computer software to have a signed windows driver [needed to work seemlessly with Win [7 possibly] 8 and newer]. You have to disable the windows check for signed drivers for the software to work.
Any luck on getting your truck scanned and getting codes. I have the identical model truck and on mine it was the dash switch, but that was a wild guess since the lights weren't even come on, on the switch.
No im waiting on them to get the frame straight and see what happens from there
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
