6.2L Active Noise Cancellation
2015 Sierra Denali with 6.2L: I have an aftermarket amp and sub getting signal from the Bose subwoofer in the center console. I am getting significant noise, but it does not sound like normal alternator noise. I have a hunch its Active Noise Cancellation throwing the engine noise cancellation into the Bose sub, which is the amplified by 400watts into my subwoofers.
Has anyone else had this issue? Solution suggestion?
Possible to disconnect or disable Active Noise Cancellation?
Great forum, thanks for the info everyone!
  • 3 weeks later...
I also have a very loud harmonic or droning sound. This is a significant flutter coming from the speakers and subwoofer. It is happening at neutral throttle or deceleration at 1200-1500 RPM. Very annoying. It just started.
***UPDATE*** Just discovered it was a couple of business cards I had stuffed up in the visor. It was obviously playing havoc on the ANC microphones. Whoop! Whoop! all better now. The noise was so horrible and loud it about makes you want to climb out of the cab. Hope this helps anyone else trying to troubleshoot their low drone sound.
  • 1 year later...
Very interesting discussion.  I didn't know my truck had ANC until a friend riding with me remarked several times how quiet the truck is.  Then I looked at the spec sheet which says it has ANC and now I know it's for engine noise between 550 and 3000 rpm.
  • 10 months later...
Digging up old thread. Can anyone tell if or when ANC is working? I have 6.2L Bose but upgraded the Bose sub to JL stealthbox 10" and JL 300 1v2 amp. I hooked the stock bose subwoofer wires to the LC2i then LC2i to amp. It seems like ANC is not working but i never noticed it on the stock system.
Does ANC only run the subwoofer? Or it uses all door and dash speakers + subwoofer?
  • 2 months later...
2 hours ago, Michael T Mecca said:
Question--2019 AT4 with 6.2L and Bose stereo. Noise cancelling system yes??
On the 2018 the option code is:
NKC - ACTIVE NOISE CANCELLATION
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
