Trying to track down why everything on my 2000 z71 works besides the temp and compass on the rear view mirror. Starting with the basic which is fuses. Anyone know what fuse this connects to? I've searched all through the manual but can't find anything.
Not sure about yours, but there is a power button on my 08 mirror that switches the compass/temp display on and off. Since we're starting with basics, figured I'd throw that out there.
I'd also say, check the plug on the back on the mirror. My previous truck was giving me same kind of trouble after a windshield replacement. It turned out the installers didn't fully install/seat the plug, it was cocked on an angle so it "felt" tight. Once I unplugged it and then fully plugged it back it, never had trouble again. It's an idea.
Cool thanks guys I'll check out the plug. And idk about any power button on mine I believe I just push the comp or temp button and that should turn it on. Least that's what the manual is saying. Wish I could figure out what fuse it was.
For 1999 it's fuse #4 10A GAUGES in the IP fuses. I would think 2000 will be the same. At the connector pink wire in cavity 1 should be HOT in RUN. Black wire cavity 2 is ground. Cavity 6 & 7 wires go to the temp sensor.
  • 4 years later...
I have a 03 GMC Sierra  and the mirror that has temperatures and compass in it worked when I first got the truck. The screen on the right side corner of the mirror is blank. I bought a used mirror off of ebay and I worked fine for a few months. Now I have nothing. I have a friend that is good at fixing electronics boards. He said that everthing looks fine with both mirrors. I just recently changed the ambient air temperature sensor behind the grill and still will not work. Does everyone have any ideas what I can check out to get it to work again. I don't know to get a other used mirror or forget about it. I would like for it to work. Thanks for anybody help.
I haven’t heard you state the obvious is to turn on the mirror with the on/off switch that is on the left front next to the Onstar. I’m sure you’ve pushed it and just didn’t say you did.
I’m having a problem with my rear view mirror because it stays dimmed all the time. Any ideas for me to try?
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
