Upper Control Arms
matt_s
Hey guys so when we installed my 7" RCX lift I think either buddy or myself caught the boot on my upper ball joint and its starting to make some noise and have some play in it. Before I ordered my RCX lift I called them to make sure it would work with the aluminum control arm, they said it works with either steel or aluminum doesn't matter. So my question is whats a good replacement Ball joint / upper control arm? Dose it matter if the arms say steel only? Can I replace just the ball joint in the stock arms? I don't wheel my truck its a street queen (that's why i have a side by side) trailer hauler. I don't need anything fancy or super expensive but i would rather replace both arms with something stronger. Will the RCX arms that state they are for a 2013 work in these new trucks? I can't really afford or justify the $600 plus for Cognito.
I personally would just do it the right way and get the cognito.. You spent all that money on the lift you shouldn't cheap out on one thing
Every lift I have seen so far, including both I have had / have for these trucks greatly depend on the steel vs. aluminum control arms.
The RCX lift does limit your travel greatly, that is why most people end up doing the arms anyways. Cognito is where it's at for value and performance but Fabtech makes a nice set for us also but the pricing is very similar.
Will the RCX arms work? They say there for the previous generation.
theres another topic on here, but it talks about using the upper control arms from the RC 3.5 kit that are angled to correct the ball joints. I believe they arms are 250 and they have it for either aluminum or steel versions.
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
