What can I run with 20s?
Hey y'all.
I have the factory 20x9 chrome wheels on my Silverado.
I want to run 33" tires.
I am planning on at LEAST a level, most likely a 4" lift.
What is the minimum I need to lift in order to run 33"s with the 20" wheels?
Thanks!!
I think you just need to level to run 33"
Okay great. I'm planning (right now) to get the Zone 4.5 lift. So I definitely shouldn't have any problems with 20" wheels and 33" tires. Thanks guys.
Hey y'all.
Thanks!!
I have the Zone 2" Level Kit with Toyo Open Country AT2 275/60R20 tires on mine. They're advertised at 33" but really measure around 32" on the vehicle for speedo calibration.
Do you really need to level for 275/60/20's? Radius is only half an inch more than 275/55/20-s.
