power folding mirror stopped working!
My passenger side pwr/m isn't folding in or out. If I push it in by hand it won't come back out unless I do it manually again. Has anyone else experience this on there gmt-900?
Yes, it is common. My '09 Denali has the same problem - but I don't care because I just got the HD towing mirrors for it.
Do you hear the motor turning when someone presses the switch? The gears are prone to breaking. If you hear nothing, it's an electrical issue.
I can hear the motor running so I guess the gear is broken. Can the gear be replaced or does the whole mirror need to be changed?
  • 1 year later...
Does anyone have an answer this? I have the same issue now.
  • 1 year later...
On 12/28/2016 at 4:45 PM, montyss said:
If its the gear that's broke on the power fold you need to change the mirror
No  -  there's a company that sells a BRASS version of this gear which is pretty indestructible.   Its likely all that has happened here is either the power fold motor has died, or the stupid plastic gear inside the unit has broken.  Both have terrible reliability.
http://www.gruvenparts.com/shop-by-car/gm-truck
Look at the 1st item on that page.  You can upgrade the mirrors cheap with a much better motor and a gear thats NOT STUPID PLASTIC.
Cant believe GM put plastic in there, and I cant believe people replace entire mirrors or go through all that trouble just to have mirrors with more shit plastic gears in them.  The 1st time you go to the car wash and they manually fold in those power mirrors, the plastic gear usually strips or breaks.  Its unbelievable.
  • 3 months later...
This is a great video.  Note that GruvenParts.com now makes the gear brass, and you can buy it preattached to a new main shaft so the whole process is alot easier now than in this video.  They also sell the entire drive units so you dont have to do anything but swap out the old one with the rebuilt 1.
All details here, check out the 1st product  -- https://www.gruvenparts.com/shop-by-car/gm-truck
  • 4 months later...
Has anyone tried to install tow mirrors ?  Those also have power fold and power telescope.  I wonder if its possible ?
Who sells power fold and telescoping tow mirrors for 900s???
