1" Level
So I will be picking up my 2015 2500 SLT 6.0 on tuesday and was looking to level the front just 1" or 1.5" or so because I hate it when people completely level a truck then it squats when carrying a motorbike or something light like that but think the factory rake is a bit much in terms of looks. I have read a few things about people just adjusting the factory torsion keys and having ride quality issues, but if a guy just does 1" instead of going for 2.25" will it still feel noticeably different? Also can that just be done in your garage and is an alignment mandatory?
So I will be picking up my 2015 2500 SLT 6.0 on tuesday and was looking to level the front just 1" or so because I hate it when people completely level a truck then it squats when carrying a motorbike or something light like that but think the factory rake is a bit much in terms of looks. I have read a few things about people just adjusting the factory torsion keys and having ride quality issues, but if a guy just does 1" instead of going for 2.25" will it still feel noticeably different? Also can that just be done in your garage and is an alignment mandatory?
I would look at the Rough Country 2" level kit. Beside being a popular level on this site, my truck still has a rake to it (about an inch, maybe a hair lower). This kit will also allow for some slightly bigger rubber if you want later on. I tow my 23ft boat that weighs around 5500lbs, it sits almost level, maybe just a slight reverse rake, but it sounds like you'd be towing less so this shouldn't be a problem for you. Look at the pics in my gallery for an example.
Thanks for the input. I'm just not sure about levelling it quite that much, in my head 1-1.5 seems more where I would like to be, but once I get the truck on tuesday maybe I'll get a better idea. Im also having the dealer install some 275/70/18 Wrangler Duratrac tires so thats probably about the size I'll stay with, I may potentially get 20" wheels down the road but would probably stay with that 33"ish size range still. As far as hauling and towing, the motorbike was just an example of what I don't like about too much levelling, I do have a dirt bike and a street bike but my main towing will probably be a holiday trailer or cargo trailer. I sold my smaller trailer that I towed with my F-150 and will be looking at getting a new one soon, sizes Ive been looking at seem to mostly be 7-9000 lbs. Im fine with the back end being a little higher too I just under no circumstances want the back to be squatting because I hate that look.
Turn the torsion bar adjusters 4-5 turns. One full rotation of the adjuster bolt nets .2" of height change.
Ok I'll give that a shot when I get it, I haven't looked at the suspension geometry that close so far, does that require an alignment when you mess with those?
Yeah just turn the adjusters no since wasting money on a leveling kit and get the same results just bring the front wheels off the ground first before turning the bolts this makes it easier to turn the bolts and puts a lot less stress on the threads and heard people snap the bolts off by not doing this. Yes the ride will be a little stiffer but I never cared because its a truck and not a car.
Yes. It will mainly throw toe off. Camber and caster stay well within spec.
Ok thanks for the input guys I will mention I would like this done to my dealership
Well, leveling either the front or the back will end up the same with a full load on. I opted for dropping the back with a set of McGaughy's shackles for about $70. Perception is in the eye of the beholder, but the front for me was tall enough. The back rake was too extreme. I have compared to to my cat sticking his butt in the air when I pet him. Lowering the back, raising the front, either way, when you load it up it will look exactly the same overall. Even with the back lowered a little, I still have some rake and more than ample clearance crossing hillside terraces on farm ground, crossing ditches, etc. Have thrown nearly a ton of concrete or bentonite in the back and it didn't squat much at all. Doesn't even change look at all with a couple of 55 gallon drums of oil in back.
And I didn't have to do an alignment on the front after the shackles installed. About as simple and cheap as it gets.
I had contemplated the rear drop, Im pretty sure theres a 1 1/4" bumper that a guy could just take out and like you say thats super simple, but I'm going with a little bit bigger tires 275/70/18 (about 33") so I thought the extra little bit of clearance would help out, and If anything I prefer a truck to sit a bit higher than stock, not really a fan of lowering trucks.
That would make a difference in how one would go about things.
Like other have said, just crank the keys a few turns and it will give you an inch.. Would reccomend an alignment
  • 1 month later...
I ordered those shackles also from McGaughy's - I've not installed them yet - any chance you would throw up some pictures Cowpie?
No, didn't take any pics of the install. Had my local shop in town do it when I had them change out the factory fill transmission fluid and filter. This pic is the pickup currently with the McGaughy's on. Lowered the back by about two inches at the axle, yet still plenty of rake. But very noticeable when getting in and out of the bed. The step up is not nearly as bad as stock.
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
