Are all LTZ's Z71's?
  • Replies 37
Mine is not a z71 and has the off road screen..
Am I the only one without this? I can't tell if I care or not. Does it display anything relevant? Or just a pretty 4x4 typeface? lol
Also on the Z71 package it cost more if you want the decals and badge on the truck sides, luckily if you got the All Terrain on the Sierra there is no Z71 badge on the front fender, the only option you had was the Z71 sticker on the bedside if you wanted to pay the extra for it.
The Chevy's automatically get the Z71 decal.
LTZ Silverado's with the Z71 package also get the better looking grill and skid plate.
Z71:
Profile-2015-Chevrolet-Silverado-2-12-15
Regular LTZ:
2015-chevrolet-silverado_1500-fuquay_var
Z71 package also gives you the off-road screen in the DIC.
This is only on the 2015+ trucks, the 2014 trucks did not get this feature either. It can be added via the aftermarket but not thru the factory/dealer.
I just checked what it does. How can this be added via aftermarket? It looks pretty neat.
That's a '15 4x4 option. Mine isn't a Z71 and I have the off road screen in the DIC.
Hm, interesting, hadn't heard of this before. What does it display?
It shows steering angle, front and rear truck angle, and side angle all shown in degrees.
Chris on the board said he could add it I believe, I am tempted to have mine done when I am on vacation along with the option to drop the windows via the remote as well.
Mine is a 2015, not a Z71 and doesn't have it. At least not that I have found anyway.
You have to check the box in settings. It is in there..
Just checked all settings and still haven't found it. If you get a chance can you post what sub menu it is in? Not that big a deal but if I have it I would like to turn it on
I can almost bet that option is only on the 4x4 trucks and as said prob only the ones with the Z71 package on them.
I was wondering if it was the other way around. I have a 4X4 LTZ, but not a Z71.
to answer some questions in regards to the off road screen...use the steering wheel controls to scroll thru ur driver display, go to setting, theres a menu in there to select what u see on the info screen...trans temp, engine hours, off road info, etc. also gives u the option to remove info u dont want to see.
Thanks! Found it. It's in settings, then info pages, (has a i with a circle around it, then scroll right. Thought I had been in every screen, that one is buried deep
high capacity air filter
I don't understand this line of marketing from GM. When I changed my air filter, the part number was the same for all 5.3L V8 engines regardless of whether the truck was a Z71 or not. And the replacement filter was exactly the same as the filter I pulled out.
    JohnRoy
    JohnRoy
  • Who's Online   5 Members, 0 Anonymous, 644 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
