wanting more aggressive tire for HD
rockrv
I have,a 2013 sierra 2500hd with factory 20" wheels wanting to get rid of the good year sra. Any suggestions? I'm leaning to the bfg ko2 in 275/60r20. The factory size is 265/60r20. The only thing bad is the bfg are only load range D and my local belle and discount tire won't even put them on for me. I need load range e they say.
That may be a "CYA" policy they have at their store.
If the D-range tires are not equipped to handle the full load of your HD, it makes sense for them to not want to go ahead and just slap any tires on a pickup. Good for them for not being careless....Now if trailer dealers would stop selling giant trailers that are too heavy for the pickup they are towed off the lot with, the highway would be a lot safer.
Have you looked at any Cooper tires? I have been running Discoverer AT3's with the "E" load rating on my V-Max and they have been great. They also come with a 50,000 mile warranty.
Ya I've looked at the at3. I just love the look of the bfg. I've been wondering about the cooper atp they might look a little more aggressive than the at3.
I have the ATP's on my half ton, they're a good tire. I've had an issue with them cupping but I believe it was from running too low psi over the winter and fighting side winds; my alignment is dead on. I increased the PSI and the issue seems to be correcting itself. The snow performance impressed me, they seem to stop really well on ice/snow. I did Berthoud pass in 2wd with about 6" of snow and they barely slipped.
It seems like the Cooper ST Maxx and Goodyear Duratracs are really popular on the HD's. I would not hesitate to get AT3's though, I've been hearing great things about them as well, they may even be my next set. I won't run anything less than a 10 ply on my half ton, let alone on an HD.
I just got BFG AT KO2's on my 2500HD. 285-75-16. I've always had load range D on them since 2003. I get home today from Costco where I bought the tires and was shocked when I looked at them.......
Load range of E and a max load rating if 3750!
I liked the A/T3's I put on our '10-1500. Great winter traction, no issues in rain, etc.
And the fact they have a mileage warranty just tops it off!
A buddy has a set of the Toyo Open Country ATII (I think it is). He likes them a lot! I know someone else with them as well on a '13 2500HD and he can't say enough good things about them! He has the 295/55/20's (will need to verify the sidewall, it is the 295's though) with the t-bars cranked just a couple turns.
Good luck and let us know what you go with and what size.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
