Waiting for Michelins
Was going to have 6000 mi tires rotated and balanced this morning and as usual an issue came up. One tire had a large screw imbedded next outside grove and considered non repairable. Guess could have ordered another SRA but decided to replace all with Michelins. Waiting for them now and with two large tire distributors nearby should be delivered this afternoon. So all the other stuff I've been saving for is on hold
I'd still have them repair it and see if it holds. I've been told the same thing before on my tires and just went with a patch/plug. And why all four tires? Why not just buy one? Or even a used tire?
:chevrolet: I left my SRA's at the dealer and took my Michelins home with me and never looked back. Good trade!!
Most all commercial shops will not repair anything from the outside tread block to the sidewall for liability reasons. Sure you can take it to a less than ethical shop and have them do it, but why? I wouldn't want to take a chance on that repair. If the tire is under-inflated at all and heats up the repair could fail.
SRA's were ok and looked sporty with white letters but to me made a lot of road noise and no traction in rain. I slid and spun taking it easy with traction control on :wtf:
What model Michelin did you go with?
LTX M/S 2 haven't been out on highway yet but can tell difference driving around town. Guess could risk a plug or bought a new tire but was going to switch to Michelins eventually. I've driven delivery and service vans with M/S and Michelins on a Monte Carlo I owned few years ago
I've been debating keeping my 20" wheels and switching over to the Michelin At2's. 90% of my driving is highway and they seem like they would be a great improvement in dry and wet conditions compared to my OE LS2's. Post up some pictures!
Truck looks kinda plain now with blackwalls, maybe need chrome mirror caps and door handles . Considering removing mud flaps
65-75 hwy this morning, truck shook all over,back to shop Saturday for rebalance Dang it! Took it first time for slight shake 70mph with Good Years
Have you had vibration issues on your truck before switching out to the Michelins? My OE Goodyears had to get re-balanced about 3k miles ago because I was getting a terrible seat vibration at around those speeds. I was luck since the issue was fixed by simply road-force balancing them at the dealer. Other members have not had the same luck and have had differentials, shocks, and other items replaced.
You might want to take your truck to the dealer and have them balance your new tires. I'm not all sure what "road-force balance" is different from the traditional "balancing".
Truck had slight shake 70 mph and made an online appointment for dealer to check balance but never got a confirmation so just went to tire shop. I wasn't pleased this afternoon spending a good amount of money and having to clean gunk of my wheels from greasy balance machine. Will contact dealer tomorrow but so far the Michelins handle and ride great till 75 mph, and quiet which I enjoy after hours of high pitch whine from 8 deep lugged drive tires on a semi
I would recommend a road force balance for your new tires. The machine is the latest technology and has a large weight that rolls against the tire as it turns. This weight simulates the load of a vehicle on the tire/wheel assy and provides a more accurate balance. Both tires and wheels have a heavy spot. The heavy spot on the wheel is usually at the location where the valve stem is drilled. The heavy spot on the tire is where a spot or paint mark is placed. NEVER let an uneducated tire guy place the spot on the tire at the valve stem. Best place for the spot is 180 degrees away from the valve stem. If a lot of weight is required on one wheel, your dealer can break the tire off of the rim and turn it 90 degrees at a time until the minimum amount of weight is required to balance it. If the problem continues, tell them you want a runout gauge used and make certain your wheels and tires are within spec. A few thousands of an inch may not seem like much but makes a huge difference at 70 mph. At this speed your tires are rotating at about 900 ~ 1000 rpm and there is quite a bit of rotating mass to cause a vibration. You may have to find someone with vibration knowledge (or that cares) and work with them until this is resolved.
Called dealer today was told they had same equipment and suggested take it back to tire shop for rebalance. Everybody brags on their good service including my Bro inlaw, I messed up and went to the old shop ,they have two other large shops with better equipment.
    B07
    B07
  • Who's Online   0 Members, 0 Anonymous, 733 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
