New from Texas
Hey guys, new member from south texas. I own an 01 chevy 1500 with 150,xxx miles or so and I love it, never let me down just minor fixes here and there. We'll now I'm in the market for a diesel and I definitely want the denali 2500 hd 4x4, so my ? Is should I buy a 15 with rebates or wait for the 16 with a few changes to it?
Thanks in advance
Welcome to the group, everyone will have a different answer, but I would take the 2015 with rebates now.
Just to give you guys an update I went ahead and got the 2015 denali HD I pick it up tomorrow
Will post pics of it tomorrow, had them detail inside and out and put tint before receiving it
