Diablosport In-Tune
Hey guys,
I just purchased a DiabloSport In-Tune for my 2009 GMC Sierra 5.3L
I have a few mods on the truck as follows: K&N CAI, Magnaflow Muffler connected through the factory pipes and just recently some larger Toyo MT tires size: 33/1250R-20/10
I'm looking to turn the AFM off and set the tune for performance. I'd also like to add the new tire size to the tune but I'm not sure how to do this.
I'm not the most savvy mechanic and changing the rev points seems pretty complex. Can any of you guys give me some suggestions?
It's plug and play man. Like, literally. Open the box it comes in and follow the 5 steps to tuning your truck.
Those Diablo Sport tuners and any other big box store 'tuner' are very basic.
Those one size fits all style canned tunes are designed to work for all engines no matter the vehicle. The problem with that is no two engines are identical in performance.
That Diablo tuner may improve some things a little but nothing comparable to the performance gains you will see from a true custom tune. There are guys that actually have the DS software and can make a custom tune that is a little more specific for your truck.
DiabloLew is who people seem to give good reviews, stay away from others because there are a few.
Sent from my crappy iPhone 6
using Tapatalk
I've used the In-tune before on my Challenger for a basic performance tune but entering the tire size / changing the rev points seems a lot more complicated.
using Tapatalk
So I just feed this guy some info from my truck and he makes me a custom tune ? That sounds pretty cool! Is it expensive to have him do this?
His website should have all the information you will need, including price for a tune. It explains the logging procedure and how to send the needed files through your email. Not that difficult really. All you need to do is follow the step by step instructions.
Just be ready to put miles on your truck and keep sending logs because it seems you have to do a lot of them for some reason with the Diablo tunes.
I had a tune done by a DS tuner and it seemed like a shit ton of driving and logging needed to be done, and several hundred miles for some reason.
The guy from Black Bear told me a couple of days ago $599 to do a custom tune for my truck. ('13 Sierra 1500 5.3)
That isn't just a tune price, that number seems to include the AutoCal device also.
You are absolutely correct... the $599 price was for the whole package. My apologies for not being clearer.
I hope to do the Black Bear tune soon as it sounds like just what I need for my truck.
The basic DS tune on my '13 was effective. The best quarter mile time with a full tank of fuel, and my almost 300lb ass is 15.5@91mph. Stock was mid 16's. The truck's drivability was quite noticeable compared to the stock tune, which went bye bye at 1k miles.
Thanks for all the info guys!
I spent a couple hours today getting the In-Tune dialed in. I selected the Diablotune and customized it a little. Turning the AFM off along with the torque management. Adjusted the tire size to my new wheels and even changed the gear ratio to match my truck. I'm pretty pleased overall but wow, the touchscreen on this one was pretty bad. Spent a lot of time trying to make the buttons interact with me. The screen calibration seemed off but whatever it worked. Im thinking in the future I might have to have DiabloLew make me a custom tune but for now it's pretty decent.
The touch screen is pressure sensitive NOT heat sensitive haha. It is a little clumsy. Have you regeared your truck?
Nope, it's all factory. I had code GU6 I believe, 3.42 was the ratio that I changed it to.
With that Diablo Tune, be sure to run 91-93 octane. The timing is advance will not like regular octane fuel and will ping terribly.
using Tapatalk
It wasn't already set to 3.42 for you? To be honest I never checked the gear ratio because I just assumed it would be setup for my truck already. I have the same gears as you. I have a mission for tomorrow!
I think it was set at 3.73 and I changed it to 3.42
    • Oh yes, someone is going to be certainly hitting up GM service/ support for a 20 year old truck.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
