hot air
need help? have 2004 gmc Yukon denali, sometimes air will blow hot on one side. turning engine off and restarting corrects the problem. has happened three times, any ideas?
Bad vacuum proportionate valve.
Many things could cause this, you should probably as a real professional.
  • Blocked Condenser
  • Broken Condenser
  • Low refrigerant
  • Broken cooling fans
These are just some of the possible reasons.
No vacuum on 2004. Electric blend doors
Yea. Had this issue. Blend door actuators are done. About a $1400 job at the dealer. The dash has to be pulled for one. I had mine taken care of in 2012.
