MPS ID3 Tag Format for IntelliLink
Hi everyone, I am really hoping you can help me out with something. I just got a new 2015 GMC Sierra with Nav/IntelliLink. It has an SD reader in it, so I bought a 64GB card, loaded it up with music and because of my OCD, I wanted the files to be listed neatly. I tried editing the ID3 tags so everything would be displayed nicely, but it seems that everything I try just does nothing. Has anyone figured out how to do this properly? I hate it when you are browsing through the artists and you see "Artist", then below you see "Artist feat. Another Artist". It just drives me nuts. I hope someone can help me out. Thanks all. :)
  • 3 weeks later...
Did you get anywhere? Would be interested in how you placed the files on the card. I have mine in folders with no playlists and it is an extra step to use the browse/more/folders method.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
