Welcome Puddle Lights projector lights.
I am going to add puddle lights to my truck but I am unsure how to wire them up any suggestions I would like for them to light up at night with the dome light circuit. I have had these on my last couple rides and think they a slick. Here are some link with the lights. Anyone done these yet on a 2014+ Silverado?
http://www.amazon.com/projector-Chevrolet-Caprice-Colorado-Corvette/dp/B00G5D9CAU
Man that is sick.. It's crazy because I just seen a commercial with that same feature... Now I'd do that
Sent from my SG Note 4 on Tapatalk
Simple. There's a few threats in how to tap into the dome light, how ever to put those on the truck I believe you have to drill the door panel in order to attach it. To tap into the dome light I used the driver side a pillar or whatever is called, the piece that goes from the dash to the ceiling. In there after you pull the cap off you will see a bunch of wires. There's 2 solid grey wires, one thicker then the other I used the thicker, that is the dome light. I just use this because is to hard to be under the peddles trying to t tap anything.
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
DROPKICK Edition
You have installed them already ? I know I would have to drill the door panels to install. My only thing is I have to run wires to all 4 doors sounds like a pita. I was hoping the wiring may be there since I think the GMC have puddle lights I guess I will have to pull a door panel off and take a look. If not ill probe the large solid grey wire and check voltage sounds like it will be a afternoon project already ordered them so I'm committed. Have them on some of my other cars and always get a lot of compliments on them.
I haven't done it but I have looked into it. Not sure of the other doors but I know driver door has a small light inside the door handle you could possibly tap into that. It is always on tho until the truck is off. But I guess is ok cus when your driving the doors are closed so you don't see them
DROPKICK Edition
I should get them this week and I will try to get some photos and a write up how to install them.
I have one of these installed. I was unhappy with the result and did not install the other one. My truck is lifted so it dimmed the light when it hit the ground. Its much easier to wire than you think actually. I have a 2014 Silverado. I tapped into the wire the lights the interior door handle no problems. The other issue is the mounting. I drilled into the door panel underneath but really didn't like how it mounted. it works and is solid but because of the overall light was dim I didn't add anymore. I get a lot of compliments when people see it but its just ehh too me. My truck is victory red and I was able to find an all red chevy logo version.
Awesome I knew there was a easier way than the dome light I was looking at it the other day and thought about it a and was like shit this is going to be a pain with the dome light. I'll give it a try on the drivers door first and see how it looks. My truck is pretty stock height so hopefully it wont be too dim. I have had them on a few Caddies and my Audi's always get lots of compliments. If they suck I will only be out $20 some time and a few holes in my door panels on a $40K+ truck.
I would love to know the size of them when you get them. I was hoping they were a bit smaller. I had trouble deciding where exactly to drill the hole (as I didn't want it coming up into the door pocket. Would love to see the outcome. I bought mine from Mr Kustom (mrkustom.com)
Looks sweet, I'm in for the updates
Got them in look sweet I like the added touch Ill upload a write up to show how i did it if anyone is interested. Thanks Skippy for the tip on using the small handle light to power them worked perfect. Also If you need to know how to pull the door off these trucks this video shows you how.
So far I have added to my 2014
Flowmaster exhaust
Limo tint
High beam mod $1
Cargo light reverse mod $1
Added under bed rail Leds $45
Now puddle lights $20 still have a extra pair maybe going in the bumper
Any other cool and inexpensive mods I can do ?
Gonna do the iPhone mirroring next week but that one is expensive.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
