2015 GMC SLT Bose audio inputs
RGatzke
I have a 2015 GMC SLT AT CC with Bose. I'm wanting to add a JL Audio 900/5 HD with a sub and components. My question is does the Bose amp use low voltage inputs or data signal for the audio in?
From looking at all the wiring on the amp and the radio outputs I'm thinking it's using data for the inputs.
In researching other posts about adding aftermarket subs and amp, it appears the signal is a digital audio signal to the bose amp.
I don't know this from experience, just what I have read.
Most folks seem to use a speaker out signal via a line converter for adding amps.
Im not sure.. but to help you out I added a sub and amp to my truck.. if your looking at the amp that came with the bose system the far right connector pin has two wires a little bit thicker than the others. These wires should be blue/grey and grey/blue and i connected my line out converter to those and ran rcas from the line out converter to the amp.
I was hoping the Bose amp had line level inputs from the radio. I really didn't want to use a line out converter for the system due to the chimes and Onstar coming through it as well.
I was hoping to tie into the line level inputs(if it had them) and running my system. I'd keep the factory dash speakers hooked up to the Bose amp for chimes and Onstar and run my system off of my amp. But I'm guessing it's all run by a data signal and not actual line level inputs.
I did notice on the far left black plug next to the brown plug there are six wires that are paired up. I was hoping that they might be inputs.
I have a line out converter going from the wires posted above to a amplifer for my two 10'' woofers and the chimes and everything is still normal sound! they are not amplified. I couldnt tell you what wires are what. On my SLE truck i used the green/green black /yellow/yellow black / white/blue white to add my aftermarket mid range speakers and subwoofer. Did that on my SLT truck and i wasnt getting any signal so the only ones I found to work was the blue and grey wires. I even looked at the back of the headunit and everything was different from my SLE truck for audio wiring. And i had no luck finding a wire diagram on this forum/google so sorry I couldnt of been more help!
    smandy
    smandy
  • Who's Online   4 Members, 0 Anonymous, 497 Guests (See full list)
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
