Hopkins InSIGHT Brake Controller
Z71hayss
I just recently installed a Hopkins InSIGHT brake controller on my 2015 without the built in trailer brakes. They are using a design that allows you to place the controller, readout, and module in three different places. It is very adjustable and perfect for these trucks if you are looking to add a brake controller. I drilled zero holes. All I had to do was plug the GM provided harness into the slot in the box to the left of the brake pedal, solder the wires from the module, and run the wires where I wanted them. I recently pulled a 14' enclosed trailer weighing around 6500 lbs from Little Rock, AR to Fort Collins, CO and had great results. The module not only lets you control the amount of braking the trailer's brakes apply from 0-100, it also allows you to adjust the sensitivity that the brakes are applied. Here is how I mounted mine. The readout is behind the key area and out of the way but also difficult to see for shorter folks. Since I am vertically gifted you could say, it is easy for me to see. The module fit nicely under the dash along with all of the extra wiring. If you wanted to, there is enough wiring to mount the dadgum thing in the back seat.
  • 6 months later...
I installed the same one in my truck, I put the display where you put your slide control and put the slide control just left of the steering wheel
You have any pics . I was planning the same thing . How well does it fit ?
Awesome thanks for posting this. The IBC was the one feature my truck didn't have and when I bought it that I really wanted and hated the idea of installing a unit down by my knees. Definitely gonna go this route.
Honestly I haven't heard great things about the OEM controllers. I think this is a much better route since it allows you to put it wherever you think is best for you. And you have a little more adjustability I believe. Plus the Hopkins controller has red lighting so it matches perfectly with the GMC's.
So question or a thought really. So with this unit you hook everything up minus the slider and order the GM slider. Anybody think it could be wired to the point it would work? A GM slider operating the Hopkins controller?
  • 3 months later...
Nice setup I wish I had seen this before I got the controller I did.
  • 1 month later...
Glad I had seen this, my buddy bought my old controller off me so I ordered a hopkins tonight. $71 on Amazon.. I have the center console so it's pretty tough to find a good place for the old school controllers.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
