Biggest Tire Stock Height?
Before anyone jumps down my throat Im sure this has been asked before but I cannot find an answer...
I have a 2015 1500 WT that came with Bridgestone Dueler 255/70R17's which look very small and are wearing like crap in my opinion. I just recently had a PA inspection from Mr.Tire and they said I have 6/32 left which sounds decent but the tires don't look like they have that much. In the rain the back end notoriously kicks out under light throttle and spins pretty good whenever I try to speed up and pass etc. I know its a pickup and light in the back end but it seems a little excessive.
I bought the truck in January 2015 and have put around 17,5000 miles on it. Just wondering if its worth getting new tires before the winter, and what size. I do plan to put the 2" level on the front but I just want the wheel wells to look fuller.
Thoughts?
Thank You
I just put 275/70/18 on mine. A hair over 33" BFG KO2s
They fit fine. Just had to pull back the carpet wheel well liners an inch or so
Definitely fills the Wells better
Sent from my SM-G920W8 using Tapatalk
Those look awesome! How is the ride with the KO2's?
Too soon to tell. I got them on drove home, picked up the kid and went to work. I work a week away. So far they aren't super rough, definitely louder than goodyears but not like other all terrains I've had.
I have been leaning towards getting them, but also considered Duratracks. I've just seen other people say the duratracks don't wear so well especially on pavement.
I have duratracs and can tell you they wear fast! they're also not true to size...I have 255/75/17 and they are 31.2" tall.
Good to know, I will stay away from them probably. Plus where I live a set of 4 275/70R17 bfgoodrich all-terrain t/a ko2's is less than $1000 which I think is pretty good. Considering somewhere quoted me $1400
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
