Atturo Trail Blade MT 35x12.5
Anyone running the Atturo Trail Blades?
Heard mixed reviews:
Pro - cheap, look good, have decent wear, good on/offroad grip
Con - sometimes wont balance right and the measurements dont add up (35" measures 33")
For that last con, I was wondering if anyone was running these tires could measure them for me. Id hate to buy a 35" tire and get a 33"
I know, you get what you pay for blah blah blah. But if they are halfway decent and half the price of Nitto or Toyo then why not try em. Assuming they balance right and are truly 35"
Dunno how true this is, but my local truck shop said aturos arw the WORST to get balanced. He said when they come in from china, they look effin square!
"Good tires ain't cheap, and cheap tires ain't good"
That is not true. BFG's for years were the most expensive and mid pack in terms of performance. Some mid pack price tires like the Cooper AT3 or General AT2 were a better tire but much cheaper. Same goes for performance car tires. Do due diligence when looking for tires and see what fits your needs.
Tyler
