Handle Covers
CFRED70
Anyone ever used the door handle covers instead of replacing the whole handle. I was thinking of replacing my chrome handles, and I liked the idea that I could always swap back to the chrome if I wanted. Also like the idea of saving a little money, but didn't want it to look like crap.
I got a pack of chrome handle covers off eBay. Included covers for all handles (including tailgate) for around $35-40 I think. I haven't had an issue with any of them. I painted mine to match the truck before installing and they stick and fit VERY well. Id buy them again.
I would be interested in a vinyl pattern that looks like the Yukon Denali door handles. Both color of vehicle and a little chrome.
They have some covers like that. Seen them on eBay. The guy has painted a strip in the center of the handles to mimic the Yukon handles
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
