exhaust options
gmyeah
short of calling general motors.....does anybody know who makes the gm pn 23462045. its a chevy silverado short wheelbase exhaust kit. i know about the borla catback ones...but this is different....just one pipe. it looks stock, but spparently had some grumble. id like to find out so i can get a sound clip of it. for example if it was a corsa sport....or whatever. i kinda like the single pipe vs the dual borla touring catback
Not sure but the muffler looks like a Corsa to me.
yeah.....a parts guy said the same thing. Its too bad GM doesn't give you a bit more information. It's like buying a pair of boots and not sure if they are the right size. At least with the catback, it tells you it is a borla. Although, it was like pulling teeth to find out it was a borla 'touring'. I now can find out how it sounds before it goes on. With the pn I mentioned....no such luck.
If it is a corsa....I think it would a fair guess its the equivalent model compared to the touring of borla. i'll have to do some more homework.
I would not assume that it is a Touring model. I had a Corsa, but it was too loud for me. So before I sold it and put on the GMPP Borla, I called Corsa and was told that they do not make a Touring muffler for these trucks; they only make a Sport for these trucks. I was willing to pay for it so that I could swap out the Sport for a Touring with Corsa. He suggested that I buy a glass pack muffler and install it in line with the Corsa to make it more like the Touring. I thought he was kidding. With my other trucks / cars, there was always a choice, but no more.
The other hint is Active Noise Cancellation which is a term used often by Corsa...good luck
Yeah good call. I'm not that familiar with Corsa at all, so I need to do some homework. But, I do know for sure the borla catback is the 'touring' model. I spoke with borla directly and were very aware of the pn, etc. the sound should be the same, but that gm borla touring is every so slightly different than the non-gm borla touring exhaust (flapper vs no flapper valve). I'll do more homework and see what I can find if this other system is really a corsa and what model. Thanks!
I too confirmed that the GMPP Borla is the Touring model. I would recommend calling Corsa too. They are very nice to talk to, but didn't offer me much of a solution. If they had a Touring for this truck, I'm sure he would have helped me.
I talked with Corsa and sure enough......they were great to talk to, so thanks for the tip. I also found out that the exhaust I was referring to above is indeed a Corsa. Here's some infomation on it. Hopefully this helps anyone considering this option.
GM PN 23442234 (GMC) 5.3L short wheelbase
GM PN 23462045 (Chevy) 5.3L short wheelbase
Both of these are the 'Performance Exhaust Upgrade Package'. This is a single pipe exit (just like stock). It is a Corsa with the sound level being inbetween a Touring and Sport. The Corsa rep mentioned to me the closet sounding clip would be on Corsa's website under PN 14870 (or 14871). It would sound just slightly different. It does not have a flapper valve....like the Borla does. Corsa rep thought but was unsure how noticealbe the V8 to V4 transition would be....and suggested a 'active fuel range disable device' to plug into the pickups in order to avoid that to keep it in V8 mode all of the time.
For what its worth, I'm glad I found this out...but GM should make this WAY easier. It was like pulling teeth to figure out the Borla was the 'Touring' model......and this Corsa was even more of a pita to figure out. Do folks generally drop this type of coin without knowing the model and sound of the new exhaust. Glad I found the details out......just need to decide now!
The only interesting/odd thing the Corsa guy told me was.....he personally wants his exhaust to blow out the side so when he's towing the cat back with the rear exit won't mess up your load (camper or whatever). Never heard that angle before.
  • 8 months later...
So is this something I can goto GM and have them install it? The Corsa exhaust.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
