Finished the install. Should take only 15-20 minutes. You need a 10mm socket and 15mm socket.
Remove the plastic guard by removing the 2 15mm bolts from the radiator support. Then remove the 4 10mm bolts from under the engine.
Remove the 2 brackets by removing the 4 15mm bolts from the front and rear A-frame crossmembers.
Install the rear skid plate using the same 4 15mm bolts in the same position as the brackets.
There are 2 holes in the front crossmember just in front of the new rear plate that need tapped with 2 of the new self-tapping bolts. Then install the front plate using these 2 new holes and the 2 existing holes in the radiator support.
I'm adding the link to my new imgur.com album, hopefully your can see them. Sorry about the crappy installed pics. Can't get a good shot without the truck being on a lift.
http://imgur.com/a/YzATY
Edited by DanY
Looks great! Plates nice and thick, looks like aluminum right?
Edit: Just looked at page 3 thanks for all the info. Might be grabbing a set!
Where does the little black plate go?
Edited by jrob56
The black steel plate goes under the transfer case with 4 self tapping bolts.
The other 2 plates are aluminum.
Check my post back on page 3 for the eBay link to get the kit for $183 shipped.
Edited by DanY
Looks great, thanks for the pictures.
Wonder if they would fit the HD trucks, anyone know if they use the same skid plates as the half tons?
Thanks a ton DanY for your help and write up on this. Should have mine in a couple of weeks and your install instructions will come in handy. You keeping the transfer case cover or selling it? I will probably end up keeping mine, the one on my truck is made out of steel because it is already rusting so may need the extra one in a few years.
I haven't decided yet. I'll probably keep it for now. Now the 10 leftover self tapping bolts may be another story. I'll keep 4 for the transfer case plate. I paid the dealer over $8 a bolt when I bought my original transfer case plate.
Edited by DanY
Some idiot dumped his ladder on the highway over the weekend.... I ran over it at 65 mph. Fortunately, it was just a small bump for the truck, but it could have easily been worse. I'm having skid plates installed tomorrow.
Just ordered mine , should be here next week hopefully , I will also post pics when I install
Can't get your link to work. Hearing about DanY having to install 2 self tapping bolts has me worried that the 2014 does not have the holes to tap into that the 2015's have. I hope that is not the case!
I didn't have to do anything special to get them to fit. Just unbolted the plastic ones and bolted up the aluminum ones.
Try this link
https://goo.gl/photos/ApfsWXDBinoRAAJz6
Sent from my Nexus 6P using Tapatalk
Thanks ajdata! So you didn't have to install two new self tapping bolts for one of the front skid plates?
You do have to install the rear 2 self tapping bolts for the front plate. There are 2 holes in the front a-arm cross member. They are sort of punched inward, not a simple drill hole, this gives them some depth for the threads to cut into. From what people here say, they are present on the cross member for the 2014-2016 models.
If you want to convince yourself, take 10 minutes and pull off the plastic splash guard. You will see the holes directly in front of where the 2 steel brackets bolt to the front a-arm cross member.
What is a self tapping bolt? When I hear that I think of a bolt with a sharp point designed to penetrate an area that did not already have a hole.
These are GM bolts that are tapered a bit. They use them on a lot of attachments to the frame without having to tap the holes. The tapered tip allows the threads to bite when you start turning it in. These bolts are 10mm x 1.5 thread. You can use regular bolts if you tap the holes with a tap and die set.
The GM part number for these bolts is 11518341. They are listed as M10x1.5x25. Retail for 4 is $37.40 with tax.
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
