Finished the install. Should take only 15-20 minutes. You need a 10mm socket and 15mm socket.
Remove the plastic guard by removing the 2 15mm bolts from the radiator support. Then remove the 4 10mm bolts from under the engine.
Remove the 2 brackets by removing the 4 15mm bolts from the front and rear A-frame crossmembers.
Install the rear skid plate using the same 4 15mm bolts in the same position as the brackets.
There are 2 holes in the front crossmember just in front of the new rear plate that need tapped with 2 of the new self-tapping bolts. Then install the front plate using these 2 new holes and the 2 existing holes in the radiator support.
I'm adding the link to my new imgur.com album, hopefully your can see them. Sorry about the crappy installed pics. Can't get a good shot without the truck being on a lift.
http://imgur.com/a/YzATY
Edited by DanY
Looks great! Plates nice and thick, looks like aluminum right?
Edit: Just looked at page 3 thanks for all the info. Might be grabbing a set!
Where does the little black plate go?
Edited by jrob56
The black steel plate goes under the transfer case with 4 self tapping bolts.
The other 2 plates are aluminum.
Check my post back on page 3 for the eBay link to get the kit for $183 shipped.
Edited by DanY
Looks great, thanks for the pictures.
Wonder if they would fit the HD trucks, anyone know if they use the same skid plates as the half tons?
Thanks a ton DanY for your help and write up on this. Should have mine in a couple of weeks and your install instructions will come in handy. You keeping the transfer case cover or selling it? I will probably end up keeping mine, the one on my truck is made out of steel because it is already rusting so may need the extra one in a few years.
I haven't decided yet. I'll probably keep it for now. Now the 10 leftover self tapping bolts may be another story. I'll keep 4 for the transfer case plate. I paid the dealer over $8 a bolt when I bought my original transfer case plate.
Edited by DanY
Some idiot dumped his ladder on the highway over the weekend.... I ran over it at 65 mph. Fortunately, it was just a small bump for the truck, but it could have easily been worse. I'm having skid plates installed tomorrow.
Just ordered mine , should be here next week hopefully , I will also post pics when I install
Can't get your link to work. Hearing about DanY having to install 2 self tapping bolts has me worried that the 2014 does not have the holes to tap into that the 2015's have. I hope that is not the case!
I didn't have to do anything special to get them to fit. Just unbolted the plastic ones and bolted up the aluminum ones.
Try this link
https://goo.gl/photos/ApfsWXDBinoRAAJz6
Sent from my Nexus 6P using Tapatalk
Thanks ajdata! So you didn't have to install two new self tapping bolts for one of the front skid plates?
You do have to install the rear 2 self tapping bolts for the front plate. There are 2 holes in the front a-arm cross member. They are sort of punched inward, not a simple drill hole, this gives them some depth for the threads to cut into. From what people here say, they are present on the cross member for the 2014-2016 models.
If you want to convince yourself, take 10 minutes and pull off the plastic splash guard. You will see the holes directly in front of where the 2 steel brackets bolt to the front a-arm cross member.
What is a self tapping bolt? When I hear that I think of a bolt with a sharp point designed to penetrate an area that did not already have a hole.
These are GM bolts that are tapered a bit. They use them on a lot of attachments to the frame without having to tap the holes. The tapered tip allows the threads to bite when you start turning it in. These bolts are 10mm x 1.5 thread. You can use regular bolts if you tap the holes with a tap and die set.
The GM part number for these bolts is 11518341. They are listed as M10x1.5x25. Retail for 4 is $37.40 with tax.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
