2013 Suburban won't start when retractable running boards are movi
First time post but long time recipient of great help from this forum. As the owner of a 2001 Chevy Silverado, this forum has definitely helped me keep that truck going. (I'm still working on an intermittent C0265 issue but I'm working through that one thanks to this forum) This post, however, is about my wife's newer ride and a quirky issue that I haven't found elsewhere. Hoping the forum can help out here...
2013 Suburban LTZ. Wife wanted the fancy retractable running boards (which in my mind are just one more thing to go wrong). Now, when we attempt to start the engine at the same time as the running boards are retracting, the starter clicks once and won't start. I have to remove the key, reinsert it and then start the engine. If I wait for the boards to retract, the engine starts just fine. Same issue occurs if the power seats are moving when attempting to start.
This is 100% repeatable...which on one hand is nice...easy to identify the workaround (just wait until the boards have stopped moving) but on the other hand concerning as I hate trying to diagnose electrical issues. Near zero expertise there for me.
Other than using the workaround, are there any ideas on what's going on and how I might fix this? Thanks in advance!
disconnect the retractable running boards, and purchase a step stool.
Hello RD,
Glad you came out of the woodwork :smoker: , Welcome to the forum !!
I'm sure someone here has heard of this problem, just it it a few days, I'm following along with you on this one
Joe
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
