Intellibeam wont activate
Utemachine
I have a 2016 Yukon and the Intellibeam wont activate. The following is what my manual says.
"To enable the IntelliBeam system, with the turn signal lever in the neutral position, turn the exterior lamp control to AUTO. The blue high-beam on light should appears on the instrument cluster when the high beams are on. Also, the system only turns on the high beams when driving 25mph"
I've tried everything and the icon indicating intellibeam is on will not come on. I've verified on my build sheet and the fog lights are not on. Any ideas? One shouldn't need to post in a forum how to use the feature of their vehicle.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Ok thanks then, mine doesn't work. Back to the dealer again. I've had it for a week and it has a wicked dash/console rattle, vehicle pulls to the right, and now intellibeam wont work.
Utemachine, I am not sure if this is the case on your Yukon but even though my build sheet online from the GMC website with my VIN # stated it had Intellibeam, my direct call to GMC today I was told it's not equipped with Intellibeam. This was one of the reasons we purchased the Denali XL. I have called the dealership already. I don't feel this is the dealership issue but more GMC issue. Everything I can find about the 2016 states it is standard equipment and not even an option. I am not happy since this was a feature that we loved on our Escalade ESV. Not sure what my next steps are going to be but I might make them take the vehicle back.
  • 1 year later...
Hello Utemachine,
We’re sorry to hear about this Intellibeam concern and certainly understand how frustrating this can be. If you need assistance addressing this with your dealership, feel free to send us a private message.
All the best,
Anthony
GM Customer Care
  • 3 weeks later...
Finally fig’d out how to turn on the IntelliBeam system. Manual not so Intelli helpful. Found a blurb on a Cadillac site, one poster said he sat in a dark garage – and hit the flash-to-pass twice, then high beam once. So I sat parked in the dark and tried the 3-step method - That did it! The 2017 Silverado Owner’s Manual clearly says hit the high-beam twice – that does NOT do it!
To enable IntelliBeam system (with head-lamps in auto):
Hit the flash-to-pass twice, then high beam once.
The IntelliBeam indicator is located down in the lower part of the tach – to the right of the head-lamps on symbol. Even the symbol is different than the 2017 manual, the “A” is actually fully inside the symbol.
The IntelliBeam indicator is green in color. (And smaller than the blue high-beam indicator up in the H2O temp gage).
If you use flash-to-pass while driving, you do NOT lose the setting. (Manual again in error).
If you manually turn on the high-beams you lose the symbol, and would have to reset.
If you turn on the fog lights you lose the symbol, but when you turn the fog lights off it comes back.
If you turn off the truck – the setting remains when started again.
  • 4 months later...
I am constantly re-enabling this from using the manual high beams. When I realize that it isn't on and try to turn it on the highway while I'm driving, people think I'm nuts with all the "flashing" that I'm doing. It's almost a safety issue as I needlessly blind other drivers while trying to turn the auto mode back on.
There should be a simple dash button to enable this. Press once to engage and have it stay engaged. Press again to turn off. Shouldn't have to do the crazy flash to pass twice then high beam once nonsense!
  • 5 months later...
I have a 2017 SLT sierra and can't get it to work, after some research I have found that it is only available if you have lane assist. Can anyone prove this wrong ?
Correct, on 2017 Sierra, Lane Keep Assist and Intellibeam are packaged together.
TQ5    Headlight, IntelliBeam, automatic high beam on/off
On SLE/SLT - Included and only available with (Y86) Enhanced Driver Alert Package.
UHX    Lane Keep Assist, helps keep vehicle centered in sensed lane
Y86         Enhanced Driver Alert Package, includes (UHX) Lane Keep Assist, (TQ5) IntelliBeam headlamps, (UHY) Low Speed Forward Automatic Braking, (UD5) Front and Rear Park Assist and (UEU) Forward Collision Alert, Safety Alert Seat
On SLE - Requires Regular Cab model. Requires (PCM) SLE Preferred Package, (AZ3) seats 40/20/40 split-bench with (H0U) Jet Black cloth interior trim and (AG1) driver 10-way power seat adjuster.
On SLT - Included with (PDT) SLT Crew Cab Premium Plus Package. Requires Crew Cab or Double Cab model. Requires (PCM) SLT Preferred Package, (KQV) heated and ventilated driver and front passenger seating, (AN3) front bucket seats and (H3A), (H3B) or (H3C) interior trim. Not available with (GAT) All Terrain Package.
    B07
    B07
  • Who's Online   0 Members, 0 Anonymous, 774 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
