Recently, my truck has been doing something weird. I dont think it was doing this before but it is doing it lately.
During my normal commu on highway, I notices it hovers just above 1500RPM when traveling at 100km/h. Recently, it feels like slipping or misfiring as the needle jump about 1-3 millimeters up and down when I cruise normally at 100 and after a while, it ramps up to ~1800 to stay at that speed. It takes a few more minutes of driving for the RPM to drop back to 1500, have not figure out when or how it goes back to the 1500 range but this happens at least 2 to 3 times on my 1 hour drive in the morning and also coming home. When it is at 1800RPM, the fluctuation seems to be nonexistent at this range.
I have searched some of the key terms, I can only find relevance to Torque Converter failing, I am at 56000km on my truck now, is it normal that this is failing already?
It has been cold lately too, but didnt do it last winter from what I remembered, it is -13 to -24 Celsius where I have noticed this issue.
Almost out of base warranty, just added the GM PP to 100000km.
I would like some pointers on what I can do to fix this if it is not normal.
I have a 2015 with the same engine/transmission. I noticed the small fluctuations a while ago, at about 5000 miles. Asked the dealer about it and was told that they all do that. For the 1500 to 1800 change, is it changing from V8 to V4 mode or V4 to V8? I have noticed that the RPMs change quite a bit when it changes.
Disabled V4 AFM using diablosport, so not AFM. Tuned it back to stock, same thing. Dropping it off on Saturday. :(
This could be the torque converter locking and unlocking, which results in some RPM fluctuation.
from: http://www.silveradosierra.com/vortec-5-3l-v8/rpms-fluctuating-t9475-10.html
#PI0680: Random Tachometer Needle Movement or Engine RPM Increase while Driving at Steady Throttle on Level Road at Approximately 50-55 MPH - (Feb 23, 2012)
Subject: Random Tachometer Needle Movement or Engine RPM Increase while Driving at Steady Throttle on Level Road at Approximately 50-55 MPH
Models: 2010-2012 Cadillac Escalade Models
2010-2012 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2010-2012 GMC Sierra, Yukon, Yukon XL
Equipped with 5.3L, 6.0L or 6.2L AFM Equipped Engines (RPOs LMG, LC9, L76, L94) and 6L80 or 6L90 Automatic Transmission (RPO MYC, MYD)
Condition/Concern
Some customers may comment on a random tachometer needle movement while driving at a speed of approximately 80-88 km/h (50-55 mph) with a steady throttle on a level road. They may also comment about hearing an engine tone change as engine RPM briefly increases and then decreases. Customers may occasionally describe this condition as a surge, flare or shudder.
Recommendation/Instructions
This condition may be caused by normal Active Fuel Management (AFM) transitions. When the engine cycles from V4 mode to V8 mode, the engine will produce increased torque and as a result the TCC slip speed may increase momentarily. This increased slip speed may be visible as movement of the tachometer needle or audible as an exhaust note change. This AFM transition from V4 to V8 mode and back to V4 mode is normal operation. The resulting small increase or decrease in engine RPM is also normal.
To diagnose if the random tachometer needle movement is caused by AFM transition, shift the transmission to manual mode (M), select 5th gear (M5) and drive the vehicle under the same conditions. Selecting M5 manual mode will make AFM inactive and the engine will stay in V8 mode. If the condition is eliminated when AFM is inactive, it is normal operation and cannot be eliminated. No repairs should be attempted.
mine 2104 chev has been doing this for awhile , cant wait to hear what tthey do for you morrislee
Most likely going in on Tuesday morning for a drive with them if they are not sure of what I am referring to as they are unwilling to drive it around for 30 minutes to 1 hour to see the problem themselves
I am betting this too, hoping this would be the only issue.
Definitely not this, if you see what I have done already in my original post, it does it when I have AFM disabled. When I am hovering at V4 as the indication in the instrument cluster, it does it too from time to time.
Alright how about this one:
from: http://www.hptuners.com/forum/showthread.php?28770-6L80E-TCC-info
from the gm service manual:
A torque converter with an electronically controlled capacity clutch (ECCC). ECCC was developed to reduce the possibility of noise, vibration, or chuggle caused by TCC apply. In a torque converter with ECCC, the pressure plate does not always fully lock to the torque converter cover. Instead, the pressure plate maintains a small amount of slippage. In RWD 6-Speed transmissions, this slippage can range from 0-50 RPM. Full lockup (0 RPM slip) is still available on some applications. TCC may apply in 2nd, 3rd, 4th, 5th, or 6th gears. The specific TCC apply points and the amount of clutch slippage are determined by a number of operating conditions, including throttle position, vehicle speed, gear, as well as specific vehicle application. Transmission fluid temperature will also affect TCC apply points.
Some more reading:
http://www.transtar1.com/TranstarIndustries/media/Transtar1/technical/bulletins/TLT-TC-035.pdf
This is normal behaviour of the transmission and nothing to worry about.
edit: Also the difference between 1500 and 1800RPMs is the difference of your transmission being in between 5th and 6th gear. When its in 5th gear its more than likely in V8 mode applying less PWMing to the lockup.
edit2: if you really want to reproduce this "issue", just make sure the transmission is up to temperature (180F+) and you should be able to reproduce it easily.
Edited by ic3man5
Doesnt sound like mine is doing what it is suppose to be doing then.
Some more reading:
and no, I have lowered the gear to 5th when this happens, RPM jumps even higher!
what diff ratio do you have in the back? 3.42 should be around 1900RPM.
Mine jumps about +-50RPM in both directions (or 100RPM total).
Edited by ic3man5
Didnt do this before, something is definitely wrong and ever since I start seeing this, the economy went down the drain :(
Dealership had to test drive it twice (after they told me they could not reproduce the issue)
They detected the torque converter slipping allowing a spike of up to 150RPM which was outside of the factory tolerance. They have agreed to replacing the torque converter.
Wish me luck!
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
