3rd cat void warranty
joshc64311
What happens if you cut off the 3rd cat and drove with it just like that?
As in no muffler or tailpipe? It'll be real loud, but probably sound terrible. You might lose some bottom end power too.
I started with cutting just the rear resonator off of mine and wasn't happy at all with it so moved up to the muffler and cut it off right prior to the inlet and sounded decent, but idle was really low if any sound and then moved up to the third cat and cut it off right after both the O2 sensors aft of the front two cats like an idiot and was a great sounding idle because it was similar to turn downs right under the cab but entirely too loud in the cab and also got a check engine light because the sensors were damn near exposed to air. lol I guess we learn from our mistakes right? That being said, I have since got true dual straight pipes installed from where I cut both pipes off, no cat/mufflers/resonators, and ran it to the back at 45 degress to 5 inch tips.I do not have any pop, crackle, or issues with check engine lights anymore and am a happy camper. Also, according to the dealership they will still honor the warranty incase of any issues with O2 sensors forward.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
