Traction Control and MPGs
Guys,
Just lifted the truck 6" and added 22's with 35 MT's. I find that the traction control sometimes kicks in when I make a left hand turn. Conditions:
- Not raining
- In 2wd
- 10-20 MPH
- Typical left hand turn, rolling, cutting off corner (not at a light but say off a main road into a neighborhood)
It doesn't bother me too much, except for the fact i lose power till it turns off. Anyone know why it may be doing this? And a way to fix it?
OKAY, now - MPGs
DIC (and my calculations through a couple tanks) is showing about 11 MPG's for my set up. Is this about what others are getting? I plan on a tune soon, but even at a 1 MPG increase, that is still pretty crappy. Note: I didn't lift the truck, or expect, to get good gas mileage, but damn, would have thought I'd get better.
Thanks
6 inch lift and a very heavy 35 inch tall tire, i would expect about 11 maybe 13 on the highway if you stay under 70. A regear would help out but also expensive.
I remember reading something a couple years ago about people having traction control issues like you are describing even on a stock truck but with a bigger heavier tire. Maybe it was on a different forum.
Did you have your speedo recalibrated for the bigger tires? Could be causing the issue with TC, and why your computer is reading so low on MPG.
^+1
Unless there is a correction for the odometer, you are travelling further than the odometer reading.
With a 6 inch lift and 20 inch wheels w/ 35 inch tires I get between 14 and 15 MPG. The best I've seen on the freeway so far is 19.5. Mine has the 6.2 with the 8 speed. :dunno:
I havent had the spedo recalibrate yet, plan on doing that with a BB tune. I knew it would be off a little but in the city 10.5 MPGs sucks!
Ill do the tune soon and well see what happens then.
I wouldn't expect much more with those big 35's....but the BB tune should help.
There is a whole thread on the stabilitrac kicking in on lifted trucks here somewhere. Some times a better wheel alignment was the fix, sometimes correcting for tire size with a tune....
  • 6 months later...
Do know where I can find this tread? I'm having this issue right now. My next step will be to recalibrate the speedometer and see if that fixes the problem.
Sorry I don't but a search should find it.
