Onstar Basic Plan Reactivation
Is this possible. Thank you.
Cheapest plan I have be offered is the:
Protection
Powerful protection of specially-trained Advisors ready to assist you, from automatically contacting you in a crash to running a diagnostic check if your engine light goes on.
Monthly Cost: $14.99*
Annual Cost: $149.90
They sent me the email last week stating my Onstar would be turned off 2-1-16. The most expensive plan that the email listed was Monthly Cost: $26.99*
Annual Cost: $269.90*.
Protection
You'll start getting a lot more emails from them in the future.
I don't plan on subscribing to onstar services as long as the phone app continues to work.
I think that is part of the deal......
Idk i never use that garbage or onstar
IIRC, the phone app should work for 5 years. Maybe someone know for sure.
I was checking mine this morning just out of curiosity, and it lists protection at $19.99/month. mine doesn't run out until June though.
The question I can't seem to find an answer to though is do I have to have an onstar subscription to keep the wifi? I know I have to purchase data, but nowhere can I find literature on having or not having onstar. There is a subscriber and non subscriber price, but I'm not sure that means no onstar but keep wifi.
have no use for onstar in the least, but wifi is kind of nice. I dislike that the yearly plan is 10gb, as I doubt I'd use it, but it is what it is. If I have to keep onstar to have wifi I'll probably can it. As nice as it is, it's not $400/yr nice lol
I understand your thought process Adam. I decided to let them turn it off and then figure out what all works and doesn't work any more. about the only thing I like and would pay to keep is the navigation, and that would depend on the price.
I let my onstar expire and most of the app functions still work. I think the "diagnostics" feature is the only one that doesn't work.
If navigation is built into your radio it will still work.
As stated, the phone app works for 5 years after purchase. But, the app's diagnostics feature doesn't after the trail expires unless you renew.
like the car map location, lock/unlock still work? that would be nice, as I would still know where my truck is when my brother disappears with the keys
I'd like to know this as well.
You get no location services. The KeyFob app services ie: unlock/Lock and Remote start still work for 5 years after the date of purchase.
Update - when my trial period ended and it was going to cost me money I called and canceled my account and never gave it any thought about the app. Onstar folks got my Basic Plan working for me with only one phone call, pretty neat app. If it wasn't for this cite I'd have continued to not have this feature.
