Elite Engineering E2X Catch Can - Shipping Time?
Hozen
Deep - thx
Anybody else's clean side separator on the loose side? Mine seems too lose...
Mine is a little on the loose side but I've seen no issues with it after romping through the desert and job sites.
Out of precaution, I've been checking all of the connections every other day until I feel comfortable.
I'm a little OCD as I've wrapped the AN fittings with teflon tape :lol:
  • Replies 34
Deep - thx
The part in the valve cover? Breather Cap?
Just out of curiosity for those of you with the E2-X, why do I have 2 check valves? I only have a single outlet on the can. Am I supposed to be installing a check on the inlet hose and the outlet or did they just send 2 for a good time, lol!
Probably packaged you one too many. If you ever decide to go dual valve you already have the check valve. :thumbs:
Thank you. That's what I figured. The can has a plug in where the second fitting would thread in so making this thing a dual outlet would be pretty straightforward. Don't need it really though on a naturally aspirated truck!
    rayredbone
    rayredbone
  • Who's Online   4 Members, 0 Anonymous, 487 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
