drivers side blows ice cubes? brrr!
'06 drivers side blows cold air when heat is all the way hot.
Please help. Tomorrow's high is like 4deg!
Need to change your heat blend actuator. Had the same issue with a 03 Tahoe passenger side. Amazon was the cheapest place I found the part. Changing it was a b!tch, but doable yourself if you have small hands. Had to come up from the bottom behind the radio.
YOu may be able to remove the cover ( pass side foot area) and get a screwdriver to push the blend door. I know these can get hot if the motor burns out. Sometimes turning on the ac for a few min, then back off can get it working as the AC blends a small amount of outside air, also the defroster may help as its related to air flow. Good luck!
Spent the last couple hours Googling the web. Some guy say it can be reset By disconnecting the negative battery post. Going to try this tonight and see how it goes. I also read if you replace the actuator The vehicle has to go to GM to be reset. Is that true?
Resetting may work and may get you heat for tomorrow, but is a short term fix. Mine would reset just by turning the vehicle off and starting again.
No reset was required after changing mine, but it was 3 yrs older. If you DIY, make sure you get it in the same direction as taking it out. Getting it in wrong and turning the vehicle on will ruin the new one.
Check YouTube for videos. You might find help for the same year truck.
Ok, found the correct actuator. Got it to go clockwise and counter to match the movement of the blend control. After I disconnected it and reinstalled the actuator. Now it won't do anything.
Pulled negative battery cable, hoping to reset.....nothing.
Anyone?
maybe add what the fix was for the next guy...
x2
DEWFPO
I overrotated my blend actuator while testing it. It was already failing. Local parts store had one in stock. They tried to sell me one for $140. After I researched it, they had a replacement part in stock for $60.
Installed it and worked immediately. No synchronization required.
Probably saved myself $400 +/-.
    appletrav
    appletrav
  • Who's Online   6 Members, 0 Anonymous, 571 Guests (See full list)
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
