Hey guys. Like the topic says Ive got a 2016 Sierra 6.2 and 8speed auto. Im modding the truck for a buddy. I installed a 5" rough country lift and 20x10 wheels and 305/55r20 tires. Actual diameter is 33.5" I'm wondering if 4.10 gears would be beneficial for performance or if it would just be too much quick shifting? I used a ratio calculator and with the 33s and 4.10 gears the trucks would be spinning 300rpm more at 60mph than when the truck was 100% stock.
IMO that's too much gear for just 33" tires
Is there an official list of what gears are available for the the rear end that comes with the 6.2? They had 3.23, 3.42, and 3.73 available in 2014 from the OEM. There's at least one guy out there with 4.10's isn't there? What aftermarket support is out there?
Edited by robvas
I'm thinking we might wait unless I get some more input here. Truck has intake and cat back exhaust at the moment.. But kooks long tube headers/catted y-pipe and black bear tune are next.
Truck currently has 3.23 gears
I found a better gear ratio calculator. Yes 4.10 would be way too much gear. 3.42 with 33s would put it back to stock 3.23 ratio and oem gears are made up to 3.73 so that would the way to go but probably not worth the $$
RPM's would be 1604 at 60MPH that's not bad at all with 4.10's
RT
Where do u find this stuff at... I wanna know what mine will be lol
Sent from my Note 4 on Tapashit
I have a calculator! LOL
RT
How do you calculate dat shiznett hommiii lol
4.10s and gm's 8 speed with stock tire diameter basically gives you what Ram offers with their deeper geared zf 8 speed and 3.92's... it would be awesome actually... well but the lack of traction won't be lol.
Good luck with finding 4.10's though.... 6.2 trucks and max tow 5.3 trucks have the 9.76" ring gear and not the 9.5"... so 3.73 is as deep as these go using 6 speed max tow parts.
Sent from my SM-G900W8 using Tapatalk
8L90 Gear ratios
First: 4.560
Second: 2.970
Third: 2.080
Fourth: 1.690
Fifth: 1.270
Sixth: 1.000
Seventh: 0.850
Eighth: 0.650
I'm not sure that you need to change out the gears with 33s. I'm running 35" BFGs with a 6.2L and 3.23 gears and my truck hasn't lost a bit of performance. It does have a tune on it but it does not lack anything. I pull a 7500 lb boat and its almost as if its not even there.
I would say let your buddy drive the truck and see if there are any issues. I doubt he will notice anything.
I went with 3.73 on mine, had 4.10 on my '12 silverado with 6 spd and yes it made it quite fast but the MPG's dropped a lot, 3.73's with the 8spd is still averaging 16-17 mpg on my daily driving and on a 300+ mile trip I averaged 21.7 mpg and that was loaded down with camping gear (fire wood) and 3 people in truck doing 70 to 80+ mph
Edited by txmuder
    • One of the few things I enjoyed about my time in the midwest was taking off on weekend drives. Unlike home, where we are boxed in by mountains and water, those rules don't apply to the inland plains. Roads connect and sprawl everywhere. While Minnesota is flat, it's not completely featureless and there are fast moving rural roads with curves and slight elevation changes. I used to relish heading out in a particular direction with no set destination, no curfew, and weaving through little townships, wherever the roads would take me. Along farms, lakes, or through the deciduous trees... It was beautiful in its own way, and the seasons were so distinct there. Fall drives yielded amazing shows of color and contrast. Summer drives rewarded with the and amber evening glow of the prairie (and lots of juicy bugs).    I do a lot of that here in my home state too. But it's much less mysterious/intriguing. I've traveled most roads in the region, and every road that's fun to drive within a good radius of my house. But every drive, even on the same old roads, is still enjoyable. I know where I can lean hard into the throttle or really throw the car into a curve. There are exercise loops for when I just need to keep certain cars limber, and much longer routes to settle in and enjoy a drive and put some miles on. All the mountains and water make for some really awesome roads for spirited driving. But not all my driving is spirited, for example, that's not really enjoyable in my pickup or this Blazer (that's still here...).   Sometimes a good drive is followed by a ritualistic wash before tucking the car away...
    • 'GMAuthority' is reporting the 2027 HD's will have the L8S 6.6L gasoline V-8.  There was some talk here about the L8S awhile back.  Not sure what changes it will have now as it seems the 2027 emissions regulations have changed from what was originally proposed.  The big question will be is L8S just a stopgap for the last 2 years of the current T1 HD platform or will it carry forward to the next generation 2029 T1-2 HD's?    I assume the L8S will still be a Gen. V engine.
    • New engines will still be using DEF. You just won't have the limp modes occurring when you run out of DEF now.
    • I am not a NOCO fan for a charger I would leave on a battery 24/7. The reason is, it doesn't really float. It waits until the battery drops to a certain voltage and then charges it back up to 14V. It's better than no charger I guess.
    • I would never do anything but lithium.   If the vehicle is stored, just turn the disconnect off. My batteries are completely disconnected form everything in the trailer when my disconnect is off. Trailers don't always come that way as some still keep the CO/LPG monitor on. When mine is off...it is off.   As far as storage temps, LiFePO4 are good down to -20°C. I would store them in a heated place if it goes below that. You can also get heating mats with a thermostat if power is available.   The way the heaters work, if it's below 0°C, if a charge comes in, it is directed entirely to the heater until the battery gets above 0°C and then it allows the charge to go to the battery.   For my Android tablet I use as a display, I can move it inside my house if I was ever in an area that got super cold.
