New from Alabama
NitrousLSx
Hey guys, new to the board. Lurked for a while and finally just joined and decided to post. I have a 2015 white diamond tri coat Silverado.
Also have a nitrous lsx Camaro
image_zps6w9ukyla.jpgu
and a ctsv
Welcome to the forums. My brother lives in Cleveland, AL. Nice collection you have. What drag strip you running at in wheelstand pic?
That was at Lassiter mountain. I live in Hayden, about 10-15 min from Cleveland.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,065 Guests (See full list)
