Killed the Ads in Internet Explorer 11
GMCSierra4x4
I know that websites make money off ads. However, I do not click on any ads, want to see them or wait for my web page to load because they are slowing everything down.
Finally AdBlockPlus 1.4 was released and solved my problems. It killed all of the ads on this forum and most other web pages that I visit. I am working on a partial solution to stop HTML 5 too. If you use IE 11, I highly recommend that you download this program.
This forum has ads? I have been running Ad blocker Plus for years, using firefox, and running Linux for the OS. Once I went to the dark side, I just can't imagine having to deal with Microsoft, Internet Exploder, all the malware, virus crap, etc..
I can use Firefox, but my wife is constantly complaining about not being able to load web pages due to all the blocking options and individual permissions to bypass them (i.e. bank websites, etc.). I stuck with IE to avoid the constant complaining, but IE 11 is a royal pain in the a$$. Without add-ons, everyone started piling on the junk with HTML video being the worst. The ads on this forum for IE 11 started about a week ago and slowed down page loading significantly.
  • 3 weeks later...
Install both. You can use fire and she can use ie.
MikeNH, on 26 Feb 2016 - 07:59 AM, said:MikeNH, on 26 Feb 2016 - 07:59 AM, said:
People still use Internet Explorer?
:lol:
I had not used it since 2009.
I brought an intel xeon home and firefox went fire raped.
Never thought I'd see the day.
I was then forced to internet explorer, the same routine since win 98...
not so bad.
It may be HDMI audio synching through vid card...windows loops a pagefile dump sometimes, but always wins. Firefox cannot dig that low...
yet. I bet they fix it.
the most vivid video I have ever seen anyway...iexplore..it is still the champ. I hate to admit it.
oh, do not block html 5. If that is a problem...your PC is toasting its retirement at it.
A habit for anyone, if you know how to static ip to your modem, and enable your modems firewall..
all browsers are happy.
I am on 1.6mbit DSL for several years. Not so bad.
I have to use adblock, my net is not big enough.
a followup on the firefox...
something updated.
it also uses html5 like iexplore did.
I guess it takes a little bit to catch up.
I also found firefox can use 64 or 32bit anyhting..
iexplore ignores all 64 bit unless you tell it.
Not sure what fixed firefox. I think a setting in iexplore goes o.s. wide... all software.
I set a 64 bit setting in iexplore
:dunno:
now all good.
it is rather freakish to see how much one xeon can do..
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 912 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
