canned tunes for now?
My intune i2 just arrived and originally I was just going to go ahead and get a diablew tune, but it is going to be a few weeks before I can get this done. Should I try the canned tunes for now? If the diablew tune doesn't make this truck shift better it's going FOR SALE.
Im using the canned tunes...Improved them enough to make driving truck enjoyable
87 octane tune
Turned AFM off
10% throttle boost
TCM tune
I did firm shifts
and took torque management off.<--big improvement
I paid for the intune and Lew tuning it up front. I tuned mine the day I got it, tons better. I haven't got around to having Lew tune it yet.
i ran the 93 octane tune, turned the throttle response all the way up, had firm shifts and it was great! still got amazing fuel mileage!
what motor rear end combo do you have? also do you pull anything? really want to get my truck tuned
I actually don't know what rear end I have. I have the 5.3 and the only thing I pull is a 18ft bass boat
if you would please update with results. i love the style looks interior motor of my truck but I absolutely HATE the trans. I really wish there was a way to put the 4speed trans i had in my 03 Avalanche in this truck. never had a single problem even after 200,000 miles
Its a miracle they sell as many of these as they have, i got rid of a tundra for this truck and my tundra would run circles around it. Much better transmission. Im going to tune it in a few days when i get back home.
PM me your VIN and I'll tell you what differential ratio you have
Tommyz71,
just wondering if you had the chance to install the canned tune?
Tommyz71,
Yes, i ran the diablo tune and hard shift tune for a few days, its was a very noticeable difference. Lew just sent me back my first custom tune, throttle response isnt near as good as the canned diablo tune. Pretty disappointed. The tcm seems better but the throttle response sucks....Wish i would have chose black bear
I'm running the 91 octane tune with firm shifts and it is a huge improvement over stock. How's the custom tune from diablew?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
