What PSI are you running on D/E load range tires?
magstar67
Just curious what air pressure guys are running that have added LT load range D or E tires?
I have BFG KO2 275/60/20s and running around 33 lbs.
Cooper ATP 285/70/17.
Cold PSI
Front 44
Rear 42
Sent from Tapatalk App - Samsung S6
I read the sidewall and run about 90% of what it says
I had Michelin E range tires on my 09. I kept them at 45 psi and could fill them up close to maximum for pulling a trailer a long distance. I found the ride unnecessarily firm with 70-80 psi for daily driving. I like the truck feel of a firmer tire but my regular passenger didn't agree. In reality, I put over 100,000 kms of mixed use driving on these tires and never filled them up past 45 psi. They wore evenly and still had life on them when I sold the truck.
Toyo has a chart on their website and based on the tire size and vehicle weight it told me 40psi. On my tundra with 305/65-18 BFG TA/KO's I ran 46 psi. Just seemed to feel the best on that truck. Haven't tried higher than 40 on the GMC.
Sounds like I'm running too low. My tires seem to flat spot when truck is parked a day or two especially when it's cold outside.
I'm going to go to 45 and see if that helps.
295/60/20 Toyo AT2 and I run about 42-43 when warm. Much more than that and they seem to be a little loose without added weight behind it.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 628 Guests (See full list)
